Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 2nd July 2006, 12:23 PM   #1
Nixie is offline Nixie  Canada
Banned
Default Winding for high voltage
In very high voltage transformers (such as flybacks), I've noticed often the windings are not neat layer over layer, but seems to have some strange pattern, probably to minimize voltage between adjacent turns. Does anyone have any information on the actual patterns they use to wind these?
Old 2nd July 2006, 05:43 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Flybacks rely on mutual inductance to achieve good cross regulation with multiple secondaries. You will often see the primaries interleaved in flybacks for this reason.
Old 3rd July 2006, 09:19 AM   #3
Hi Nixie,
yes you need to think about turn to turn voltage difference.
Side by side windings will only have a volt (or much less) between them. But winding one layer to the end and then winding a second layer returning back to the start could have many tens of volts across the enamel insulation.
For this reason two or three layers are wound together gradually moving across the layer and then applying a secondary insulation sheet before returning to the start side. This keeps the turn to turn voltage down to the voltage across four or five turns and again does not overstress the enamel.
This all relies on two flaws in the enamel insulation never coinciding with each other.
You are right to be cautious when voltages are high.
regards Andrew T.
Winding a Monster Toroid, Hum & Voltage Sag EWorkshop1708 Power Supplies 25 28th June 2011 09:26 AM
Wanted - High Power, High Voltage, Audio Frequency Transformer Manual. kimbal Tubes / Valves 4 11th May 2009 09:05 PM
high freq ETD core transformer winding technique sss Power Supplies 9 18th January 2007 02:35 PM
6BY5 High Voltage & High Current Choke Input Design P.S. snoopyma Tubes / Valves 7 28th June 2006 02:32 PM
Help with lowering filament winding voltage. G Tubes / Valves 7 9th September 2003 12:36 AM
Page generated in 0.06592 seconds (75.61% PHP - 24.39% MySQL) with 10 queries
