| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have the 150w plate amp from MCM for my sub. works peachy, except I have to get volume up a decent amount before it kicks on.
Is there any easy way to adjust that? I would like it to kick on at lower volumes. |
#2 |
had a quick look at the schematic. Something does not add up. Gain is supposed to be 68k/1k+1 =69times. But it specifies 3.4V for maximum output. I note the 68k has been re-typed. Can you check component values against the PCB? It might be 6k8! The crossover on p9 seems to be losing 12db to 15db! I think q202 and u205 are the sensitivity setting for the auto on facility, but I would need a lot more time to try and understand exactly how it works/can be altered. The bass response of the amp is pretty poor (-3db @16Hz) and again this appears to be the crossover at fault. For sub-bass use this should be at least 2octaves lower and preferably 3 to 4octaves lower. Then allow the user to adjust the response to suit the surroundings. Btw. although this amp is specified for 4ohm duty, it performs poorly at this reactance. I think it would be better to use it as an 8ohm amplifier.
regards Andrew T. |
#3 |
What did you expect out of a $50 amp?
btw, you can see this thread for info on the sub (just an 8" driver) Silly's 1st Sub -- 8" MCM 55-2421 Thanks for taking a look. If you come up with a theory on the auto-on circuit, let me know
#4 |
I agree, value for money seems incredible.
regards Andrew T. |
| Harman Kardon PA 2000 auto turn on input sensitivity | MisterTwister | Solid State | 0 | 8th April 2007 04:22 AM |
| Auto power-on signal sensing circuit | Slanski62 | Digital Source | 6 | 23rd February 2007 11:44 PM |
| increasing the sensitivity of an auto on sub amp | pjpoes | Subwoofers | 0 | 21st January 2007 01:55 AM |
| Increasing amplifier auto-turn on sensitivity. | DcibeL | Chip Amps | 14 | 26th November 2005 04:21 PM |
| Subwoofer auto power on | the_DOOMer | Subwoofers | 5 | 16th October 2003 11:12 AM |
| Page generated in 0.12260 seconds (52.78% PHP - 47.22% MySQL) with 10 queries |
