| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I have several questions regarding resitor, LED and Fuse selection thaty i was hoping someing might help me with: 1. I have a transformer that is rated 120VA with 22VAC secondaries. The rectified voltage I calculated will be 31.1 Volts (120VAC * 1.414). For use with a LM3875 opamp I would like to use a red LED with forward voltage range of 2.2Vdc 20-30ma http://www.partsexpress.com/pe/pshow...70-015&scqty=6 I calculated that the resistor i would need is (33.1-2.2)/0.02= 1.4K. So i chose a 1.5kOHM 1w resistor http://www.partsexpress.com/pe/pshow...3-1.5K&scqty=1 Is this the correct resistor to be using? This set up is for a chipamp. Would it be better to use a 1.5 ohm 12w Mills type of resistor for this applciation: http://www.partsexpress.com/pe/pshow...number=005-1.5 How do i connect the LED to a dual secondary transformer? 2. I would like to us a power jack with 10a built in fuse: http://www.partsexpress.com/pe/pshow...90-443&scqty=2 The fuse i selected is a 4a 3AG slow blow fuse. Would this work? The concern i have is that the IEC says that i need to use a fuse rated at 250v. However i can't find a 250v fuse in slow blow so can i use a 32v rate slow blow fuse with this IEC? Thanks for your help
#2 |
The first resistor you mention is correct.
I don't know what the second resistor is about. What is the LED for? If it is for an "ON" indicator, you simply connect the LED/resistor across one of the large caps following the rectifier. HERE is one of several fuses that fit the bill. The voltage rating of a fuse is known as the interrupting rating. The rating of the fuse should be greater than the voltage the fuse would see if it were open (in this case 120V).
#3 |
Hi poobah,
Thanks for the response. I still don't quite understand the fuse situation. Is the fuse that i origianlly chose incorrect? Is there a slow blow fuse that i can use with the IEC i chose? All the slow blow fuses on the parts express website seem have an interupting rating of 35V? Thanks for your help.. .this is all new to me |
#4 |
Yeah dude... there is a fuse. Click where "Here" is highlighted in blue in the last post.
#5 |
thanks for that Cooper/Bussman link. that's the first time I've noticed the Voltage drop across the fuse at rated current. 65mV to 75mV for all the fuses I have used! If only all manufacturers were as informative.
regards Andrew T. |
#6 |
All right, but i still am not quite sure how to choose the amp rating of the fuse. If the torroid has an maximum draw of 2.7 amps do i choose a fuse with a rting slightly higher such as product GDC-3.15A?
Cheers and thanks again |
#7 |
I would put in the smallest fuse that allows the amp to work over a wide range of operating conditions. Theoretically a 120VA on 120/110Vac will run on a T1A fuse but I doubt it will start on a fuse that low. It may run on T1.6A or T3.1A or the two in between. I would not recommend T4A. The closer the fuse rating to the actual operating current the more likely it will blow when the amp/operator misbehaves. Similarly the lower the fuse rating the less heat/energy generated when it does go wrong.
regards Andrew T. |
#8 |
With regard to the LED.
That 20-30mA is more likely to be the top end of the working range and will be incredibly bright! Experiments are in order, but I would not normally run an indicator LED at more than 5mA. On your 30v(ish) rail that would need 5K6, and a lot less power to waste and worry about! LEDs vary enormously in efficiency and brightness for a given current from type to type. |
| Chipamp PSU- TP resistor across fuse?? | VictoriaGuy | Power Supplies | 3 | 21st March 2009 06:04 PM |
| Fuse Resistor on AVH-P5700DVD | haiji | Car Audio | 3 | 20th October 2008 05:03 PM |
| Dumb question on Coupling cap ratings... | john65b | Tubes / Valves | 9 | 18th October 2008 02:26 PM |
| Newbie Question on Driver Ratings | 6f6 | Multi-Way | 3 | 15th January 2007 12:58 AM |
| Resistor wattage ratings | whitey_woltrap | Multi-Way | 0 | 22nd March 2002 08:20 PM |
| Page generated in 0.11367 seconds (74.63% PHP - 25.37% MySQL) with 10 queries |
