| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I picked up a pair of these audio xformers....
Z=15 ohm Primary Z=600 ohm Secondary (four pins total (no ct)) HP 9120-0018 DC current = 0 Power Level 1MW MFD by Paeco 2016 -pulled from some unknown HP gear ???They're about 1.5" square, by 2.25" high What use do these have ? thx, =RR= |
#2 | |
M |
#3 |
very low impedance mic seems to make sense. step up ratio = root(40)=6.3times. note zero DC! Way off bat, could it have been for a dynamic strain gauge?
regards Andrew T. |
#4 |
"This low profile 1:1 600Ω transformer is designed to provide isolation between modems or similar devices and telephone lines." but the two BABT ones sold by Rapid are both 1:1.
The first of these can be rigged for 600Ω:15Ω but "Each transformer is constructed with dual windings on the primary and secondary providing a wide range of impedance matching ratios to suit many input, interstage and output applications" so I guess it's a case of first find an application. ![]() A megawatt (1MW) sounds good for such a small package, must be this new ferrite & superconductor stuff.
#5 | |
any links to a suitable project? =RR= |
#6 | |
It seems to be more prevalent West of the Atlantic where metric is not adopted, yet ![]() The rule is simple;- all multipliers above k are upper case, all multipliers from k and downwards are lower case. The problem crops up repeatedly with capacitors but the 10^9 error is usually obvious. Where a bigger problem exists is mis-using m for micro rather than u. This error is only a factor of 10^3 and confusion is very possible. Please reserve m for milli, u for micro amd M for mega.
regards Andrew T. |
#7 | |
(Maybe there are versions of Spice that deviate from the standard, though, and allows M for mega. Check you local Spice.) |
#8 | ||
| goodmans audiom 51 15ohm | SGD | Swap Meet | 1 | 2nd August 2009 09:06 PM |
| How best to use the PSU xformer I have | Steerpike | Tubes / Valves | 1 | 12th November 2008 10:27 PM |
| PGA4311 600ohm input source impedance | DragonMaster | Chip Amps | 19 | 25th November 2007 04:25 PM |
| xformer for GC | meta | Chip Amps | 4 | 4th July 2003 08:55 PM |
| Page generated in 0.09693 seconds (82.16% PHP - 17.84% MySQL) with 10 queries |
