Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd June 2006, 07:58 PM   #1
rickjl is offline rickjl  United States
Default Ni cads for FLUKE 8600a
I have an old FLUKE 8600a DMM.
The way the power supply works is there is a 5 uF cap in series with the AC primary to a transformer and the secondary has a half wave bridge that charges 4 D Cell nicads hooked in series. I assume these spikes are something like a trickle charger. This battery provides the 5 volt logic supply and then the 5 volts drives a self resonant switcher that provides +/- 15.
Two of the 13 year old ni cads are shorted (does interesting things to the operation). Sounds simple, so I need 4 D Cell ni-cads with solder tabs. I find D Cell ni cads are considered obsolete and are no longer available.
So I look and they have Ni MH batteries with the solder tabs now ($19 each???). I figure all is well until I look at the product description in Digi-Key it says "FLAT TRICKLE CHARGE CANNOT BE USED".
Does anyone have any ideas or better yet a source for D Cell ni cads with solder tabs welded on?
Old 23rd June 2006, 08:11 PM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Why not solder the tabs or some wire to the batteries yourself?
D cells are pretty big and with a good soldering iron I wouldn't be afraid to overheat them. Assuming you can get normal NiCad D cells of course.
/Hugo
Old 23rd June 2006, 08:37 PM   #3
Batteryspace.com has them.
Old 27th June 2006, 12:23 AM   #4
dangus is offline dangus  Canada
Have you tried "zapping" the shorted NiCads?
My technique:
Get a car battery or some similar 12V source.
Attach wires to the 1.2V nicad, and put the nicad behind some kind of safety barrier. Connect 12V to the nicad through a hundred ohm resistor (to limit it to a normal charging current).
Monitor the voltage across the nicad with a (wait for it) voltmeter.
If the cell is shorted, voltage will be very low.
Now the fun part: take a length of say 18 gauge wire (to provide a little resistance), and very briefly (just brush the end of the wire) short across that dropping resistor. Watch the voltmeter. If it shows that the nicad is beginning to take a charge (steadily rising voltage), leave it to charge (or use a proper charger). If not, zap it again.
This worked on a couple of old Fluke bench meters I picked up surplus. I don't suppose the batteries have full capacity, but the meters are usable.
Old 28th June 2006, 07:41 PM   #5
My technique:
Forgot about that trick, I'll give it a try. The batteries are 13 years old.
This is also a surplus find.
Fluke 8500a - Need A Little Help GeeVee Parts 7 3rd October 2010 02:56 AM
Fluke 8502A? nania Parts 5 22nd May 2010 03:29 AM
Get a Fluke DMM ThSpeakerDude88 Parts 107 21st August 2007 12:40 AM
Fs Fluke 77 Dmm powertriode Swap Meet 2 22nd July 2006 07:52 AM
Page generated in 0.07995 seconds (77.03% PHP - 22.97% MySQL) with 10 queries
