Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 23rd June 2006, 12:19 PM   #1
sagarverma's Avatar
Default Can SOIC components be used with DIP?
Hello
I have SMT opamps which i would like to use.
but i have only opamps in SMT packages and all other components like bypass caps,res. and other caps etc are all the classic thru hole.
can i use the other components with the SMT ICs?
Even the 100nf cap for supply bypass is bigger than the SMT IC.
Sagar
Never Underestimate The Bandwidth of A Station Wagon Full Of Magnetic Tapes Hurtling Down The Highway...................Andrew S Tanenbaum
Old 23rd June 2006, 12:34 PM   #2
cetoole is offline cetoole  United States
Probably the easiest way is using Brown Dog adapters. I have used them a few times, and they are pretty good. You could also bend the leads out and solder them to a dip socket, or airwire it.
Old 23rd June 2006, 12:42 PM   #3
jackinnj's Avatar
you can also use copper foil -- the adhesive variety from 3M -- with a hobbyist knife cut the foil into a thin strip -- apply just as the doctor ordered.
i use SMT ceramic caps in DIP designs for bypass caps -- just tack to the solder pad of the DUT, other end to the ground plane.
Old 23rd June 2006, 12:49 PM   #4
sagarverma's Avatar
what i exactly want to know is.....the opamp will need bypassing,since i dont have SOIP caps so can i use the regular caps for that?
Sagar
Old 23rd June 2006, 12:55 PM   #5
jackinnj's Avatar
100nF and 10nF ceramic bypass caps are on 100 mil lead spacing -- no reason that they can't be used -- here's a hint from Analog Devices -- the ground connection for the bypass cap should be as short as possible -- elsewise it's a radiator --
Old 23rd June 2006, 12:56 PM   #6
paulb is offline paulb  Canada
Sagar
Yes.
Old 23rd June 2006, 01:02 PM   #7
Wynand is offline Wynand  South Africa
Wynand's Avatar
You can mix them as you want/need to.
Take the Mute resistor on the LM3886/876 chips as an example.
Most use a 1206 size SMD resistor.
Old 23rd June 2006, 01:05 PM   #8
Wynand's Avatar
The only problem I've found is that if you use for example a SMD opamp and push-through caps and you design your own PCB. The soldering of the caps is a problem, unless you have the options of having the PCB professionally made, or if you don't mind soldering the caps/opamp on the bottom side of the pcb
Old 23rd June 2006, 01:07 PM   #9
Wynand's Avatar
On the topic, does anyone know how to make diy vias?
It's easy to make pads on both sides of the pcb and joining them with a peice of wire, but my problem is having vias under, for example, an SMD opamp. The height of the solder will lift the chip too high.
Old 23rd June 2006, 01:10 PM   #10
sagarverma's Avatar
i dont have any probs with soldering the SMT ,i can make adapters etc etc and all that, but what i fear is that the normal big bulky 100nf cap(as compared to SOIP very small opamp)
,,can it have a damaging effect on the IC,,like destruction due to static on the leads of cap,or other factors(the bypass cap is placed close to IC,so its worrying me)
Sagar
using a SOIC-8 in a DIP-8 pcb bigpanda Parts 3 13th July 2006 03:50 PM
cs8414 soic to dip sunrise Digital Source 13 16th March 2006 09:06 PM
sop or soic? ultrachrome Parts 2 8th January 2006 10:46 PM
soic to dip adapter Thomas Giz Parts 4 4th April 2003 04:10 PM
Ne5532d Soic R-16 audiodoc Parts 0 7th December 2002 07:13 PM
Page generated in 0.10177 seconds (75.88% PHP - 24.12% MySQL) with 10 queries
