| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
using one leg of this dual diode, would i have 10 amp/200v rating? or does voltage rating also, get cut in half? thanks for any info!
#2 |
Did it Himself
No just current rating is affected, as they are normally paralleled.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
#4 |
Hi crippledchicken, thanks, I’m curious about this also. Your MBR20200CT is a common cathode TO-220 Schottky diode (as you know)
http://www.onsemi.com/pub/Collateral/MBR20200CT-D.PDF I was encouraged to make a simple bridge using the common cathode TO220 as well from the “What Schottky have been used’ thread. Freakyone supplied this schematic http://www.diyaudio.com/forums/showt...648#post908648 And I drew this one from it – http://www.diyaudio.com/forums/showt...840#post942840 Wondering the same thing. It seems correct, but curious as well. Hope you don’t mind if I jump in looking for an answer/confirmation as well. Stan |
#5 |
Just read the above answer, must have come in while I was writing - thanx...
| do i REALLY need a crossover?? and an amp question. and an ohm question | legendaryfrog | Multi-Way | 4 | 29th October 2006 01:39 AM |
| newbie with input tran. question and wiring question | imo | Solid State | 0 | 18th January 2006 10:10 PM |
| PS question - tformer question actually | breguetphile | Chip Amps | 2 | 30th May 2003 01:29 PM |
| old speaker question, bullet midrange question & link to speaker project | wallijonn | Multi-Way | 10 | 5th November 2002 06:03 AM |
| Page generated in 0.07648 seconds (71.11% PHP - 28.89% MySQL) with 10 queries |
