Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th June 2006, 08:49 AM   #1
Netlist is offline Netlist  Belgium
Netlist's Avatar
Default Relay with magnets
This is an output relay from a Stage Accompany SA900C.
Can anyone tell me why the two magnets are glued to the sides of the relay?
/Hugo
Old 17th June 2006, 09:01 AM   #2
dnsey is offline dnsey  United Kingdom
At a guess, it's to convert it into a 'bistable' relay. That way, a pulse of one polarity will switch it one way, and one of the opposite polarity the opposite. Saves having the coil permanently energised.
'Proper' versions are available, but are fairly expensive - this looks like a cheap bodge
Old 17th June 2006, 09:08 AM   #3
if it's a bodge, then it's a clever bodge.
I am envious of these later thinkers.
regards Andrew T.
Old 17th June 2006, 09:50 AM   #4
Netlist's Avatar
Thanks.
The coil however is permanently energized and only one of the two contacts is used.
/Hugo
Old 17th June 2006, 10:20 AM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
The magnets make the relay switch off faster.
(Stage Accompany used high quality parts in those years. e.g : retail price of the Siemens B32521 MKT on the pic was around $0.25 in production years of the 900C, SA could have used a lot cheaper cap)
Looks like Sponge Bob has killed another thread.
Old 17th June 2006, 11:07 AM   #6
johnnyx is offline johnnyx  United Kingdom
I suspect that the magnet increases the sensitivity of the coil, so that less current is needed to operate it. This makes sense if the relay is normally permanently energised.
Some high sensitivity relays have built-in magnets; the polarity of the coil must be observed, and will not operate if the polarity is reversed. I've been caught out by this when checking relays.
Old 17th June 2006, 11:58 AM   #7
Netlist's Avatar
This sounds like a plausible explanation. After all, we want it to switch off as fast as possible. The principle escapes me though.
It's an EMC Soprel 011.51-22-001 but I can't find any info with Google.
The magnets are located near the contact points and the strongest magnetic field is exactly in line with them, not with the coil. Which doesn't mean your statement is incorrect.
The two washers I inserted take the natural position as seen in the picture.
If I try to move them, they always return to that same point.
/Hugo
Old 17th June 2006, 12:39 PM   #8
Not plausible, it's an old trick.
Ed Wijnker is SOAphobic, like a couple overhere. Stage Accompany amplifiers "were" pretty expensive. The SA1600 i had went in protection mode far to easy.
EMC= Electro Moderna Components
Soprel is the factory.
Seulement pour les potes Belges:
http://www.efacec.pt/presentationLay...ocal=13&area=1
Old 17th June 2006, 02:09 PM   #9
Netlist's Avatar
Merci Jacco. Is that a division of ACEC or in any way related to it?
(Logo)
I reassembled the amp and it sounds like its build.
Clear and detailed mids and highs, well balanced sound and good control of the bass. I didn't measure but the 285W/ch is probably rather conservative.
/Hugo
Old 17th June 2006, 02:49 PM   #10
ralphs99's Avatar
Hi Hugo,
The intention of the magnets is to help the relay switch off a bit faster as Jacco has suggested.
It's a technique that is used in high voltage switching. The magnets pull the arc formed as the relay opens towards the magnets because of the plasma's negative charge. As the plasma formed by the arc is now curved rather than straight across from contact to contact, is breaks slightly sooner.
This is significant where thousands of amps are being switched as it saves a lot of contact material being vapourised. Whether it's of any real use for an audio power amp where the arc length is a fraction of a millimeter is debatable.
Another technique for breaking the arc is to blow the arc out of the gap between the contacts with compressed air. I haven't seen this technique use for audio amps however!
Cheers, Ralph.
Magnets, Magnets,Magnets! skooter Car Audio 10 25th September 2008 08:30 PM
Where to buy magnets Tenson Multi-Way 1 16th May 2007 12:47 AM
Bucking Magnets markkanof Multi-Way 3 23rd January 2002 02:32 PM
Neodymium Magnets sdman Multi-Way 7 7th January 2002 06:34 PM
Page generated in 0.11042 seconds (79.37% PHP - 20.63% MySQL) with 11 queries
