| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi All,
Just a quick one - what's the best way to identify a zener value without a schematic. It's too small to have any markings on it as far as i can see without removing it from the circuit board. Thanks in advance Paul |
#2 |
Hi w/out marking & w/out schematic you would have to remove it ,use a power supply and about a 1K resistor to limit current and see at what voltage it breaks down at.alimaj.
#3 |
you might be able to measure it's voltage in circuit. It needs a bias voltage across it to cause Zener action.
regards Andrew T. |
#4 |
Assuming of course that it's still working.
#5 |
IF it's not working, then get a new Zener.
#6 |
Use a jewelers loupe or other magnifier and view at different angles to the light. The markings are small and may be on two or more lines. Then lookup the part number at Digikey etc.
| zener regulator | till | Solid State | 29 | 26th March 2008 09:39 PM |
| 15V zener diodes | mantisory | Vendor's Bazaar | 0 | 16th November 2007 11:55 PM |
| 1N4934 as Zener? | Nixie | Parts | 5 | 12th October 2006 06:27 AM |
| C27ph Zener - help | marijan | Parts | 3 | 26th September 2004 05:24 PM |
| No zener | ding | Pass Labs | 10 | 6th June 2001 11:11 AM |
| Page generated in 0.07320 seconds (73.81% PHP - 26.19% MySQL) with 10 queries |
