Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 13th June 2006, 10:01 AM   #1
Did it Himself
richie00boy's Avatar
Question Paralleling Fuses
Is it acceptable to parallel identical fuses to get 2x or 3x the rating? The reason I ask is that the fuse holder is rated to 6.3A, but I need a lot more current. I've paralleled two fuse holders each with 5A fuse to get the desired current.
Alternatively, can anybody suggest a PCB mounting fuse holder that can take more than 6.3A? Doesn't have to be 5x20mm but that's what I'm using now.
This one in fact
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th June 2006, 10:13 AM   #2
Netlist is offline Netlist  Belgium
Netlist's Avatar
Pick your current.
/Hugo
Old 13th June 2006, 12:46 PM   #3
Did it Himself
Thanks Hugo, I had to guess at Belgian though So it would seem that 1/4 inch fuses would be up to the job? They don't really seem that much meatier than 5mm fuses.
Old 13th June 2006, 06:13 PM   #4
I_Forgot's Avatar
I don't think it is a good idea to parallel fuses.
If one path has slightly higher resistance than the other (and it will, no matter how hard you try), the current will not divide between the fuses equally. If that happens, one of the fuses will blow when the current just exceeds its spec, followed quickly by the other, since it will be the only one left in the circuit.
Also, if one of them blows and the other doesn't (I'm not sure how that would happen) you will have no way of knowing until the second fuse blows under seemingly normal conditions.
Get a proper sized fuse. If you can't get one that fits on a PCB, get a panel mount or chassis mount fuse holder. Do it the right way the first time and save yourself the hassle later.
I_F
Old 13th June 2006, 06:22 PM   #5
poobah is offline poobah  United States
poobah's Avatar
Are you designing for regulatory compliance? That fuse holder appears to be capable of more than 6.3 Amps.
Old 13th June 2006, 08:26 PM   #6
Did it Himself
The catalogue says it's rated at 6.3 amps. I'm wanting to pass an RMS current of 10 amps.
Old 13th June 2006, 08:32 PM   #7
Netlist's Avatar
I noticed that you have to copy and paste the link I provided.
I'd go for the 20A fuse holder from Bussmann.
/Hugo
Old 13th June 2006, 08:34 PM   #8
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
I think that 10A is not a problem. In my opinion , the best solution is to solder the fuses , if you don't plan to replace them often.
Lukas.
Old 13th June 2006, 09:17 PM   #9
Did it Himself
/Hugo
A 10x38 mm C10 type fuse, that looks OK. My usual catalogue doesn't carry the clips, but I suppose it's no problem getting them from Farnell.
Old 13th June 2006, 09:19 PM   #10
Did it Himself
Lukas.
Thanks but soldering them is not an option. I'd also be wary of the fuse insides breaking/desoldering if I were to solder to it.
Paralleling transformers??? dfdye Chip Amps 10 30th January 2006 05:26 PM
resistors for paralleling ejn327 Chip Amps 8 7th February 2005 08:10 PM
Paralleling Transformers metal Chip Amps 8 7th March 2004 09:48 AM
Paralleling LM3886's-the right way janneman Solid State 15 4th November 2003 11:59 AM
paralleling mosfets in BLS SteveG Pass Labs 14 7th February 2002 09:20 PM
Page generated in 0.09850 seconds (77.52% PHP - 22.48% MySQL) with 10 queries
