| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
A friend of mine having problem printing boards, it doesnt matter if hes printing directly or making a pdf.
The board always gets too small, not to scale at all, wrong settings somewhere? I can print boards myself, in the correct size, but i cant find anywhere to fix his problem..
www.joddla.net/audio/ |
#2 |
If he is having problems with the film from a PDF file being slightly too small or large check the settings in the PDF format. For example it is not enough for the zoom window to be 100%. If you open up the zoom window and check at the bottom make sure the 'actual size' is checked and not the 'fit width' or 'fit page' - you will not have a true 100%, it will be slightly off - I learned this the hard way. Also, after you print the film but before exposing and etching, place a couple of componets on the film as a double check, terminal blocks and dip chips work well.
Hopefully that will do it... edit: Also, the scale factor in Eagle should be 1. |
| Eagle Question. Printing for Toner Transfer meathod. | bigmike216 | Parts | 8 | 29th July 2007 07:01 AM |
| Eagle printing question. | ashok | Everything Else | 5 | 25th July 2007 04:09 PM |
| Printing PCBs | eeka chu | Parts | 11 | 15th April 2007 01:32 AM |
| Eagle under X11(mac) and printing PDFs | pinkmouse | Everything Else | 12 | 9th April 2005 09:16 AM |
| Printing on metal? | more_power | Solid State | 4 | 18th October 2001 10:36 PM |
| Page generated in 0.06265 seconds (70.00% PHP - 30.00% MySQL) with 10 queries |
