| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
#41 |
AndrR
pre-prepared responce, as I didn't say I didnn't believe, I asked questions, and for the record I dont believe in anything, life is but an illusion, here the reply: If I am to learn anything, then why can I not question. Anecdotal information is of no use to me, I would like empirical data so that I can understand what is causing the change, and what effect electrically are taking place. This data can be collated with other experimental data and I can make a decision based on facts. That is what engineering is, and audio reproduction is engineering based, when I am trying to improve my system I am not creating some art work or musical instrument, I am building or re-engineering a tool, that's function is to reproduce music with the maximum fidelity, only by a combination of measurements and listening can an engineering decision be formed, and only with hard empirical data can you reproduce and determine how the change is made and what path to improve it more (if a change does in fact make an improvement).
#42 |
Further if the tweeter sounds to bright I would not expect some minor change to smooth things.
Simon7000, I guess this trick if for plastic film based caps? |
#43 |
Any plastic or non hermetic capacitor will be affected by moisture content. This decreases from use. As water is slightly polar there is voltage induced movement of the molecules. This may show up as an increase in distortion peaking at some frequency that could be influenced by film type and thickness. As the capacitor is used or even placed in a warm environment the humidity level in the film drops.
#44 |
Depends on the plastic. Mylar will pick up a few tenths of a percent (I think this was what Doug Self was seeing in his Linear Audio article). Polyprop, polystyrene, PTFE, as close to zero as you could want.
If there's a sucker born every minute, where do the rest of them come from? |
#45 | |
Polystyrene and teflon are considered the golden boys of caps and are well known as very stable designs. But there is a cheap brand of polystyrene caps that do not seem to perform as well as others. As they even have a bit of different optical quality from the better ones I suspect either regrind or just a lower quality of resin. Then there is always the issue of corrosion at the connections in extreme cases of moisture exposure, although I haven't seen that in any in use capacitors. |
#46 |
Far more likely that than the film- an example of why I avoid "audiophile" caps.
#47 |
When I get some 'first off' plastic parts (ABS, PC generally), the moulders put them in a sealed bag with a drop of water for 24 hrs, this improves the materials properties by a small amount...I was surprised when I first learnt this as I would not have imagined that plastics can absorb water.
As I dont use audiophile caps, just standard available caps from Farnell etc I dont supose I'll worry about any humidity caused changes. |
#48 |
This is where a boat guy would mention to read up on Adolf Fick.
(epoxy resin sealing rules the galaxy, but i rather stick to aluminum if you don't mind )
Not so much,.......if it says "ZM" in the corner. |
#49 |
I think old electrolytic capacitors become better (less then 50-63volts)after using some ten hours so the people who does not know about "reforming caps" thinks that it is burning in.So it became a trend
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components |
#50 | |
Actually nutty suggestions aside I also notice chances in audio output of coupling caps after running for some time. To my ears they smoothen out. I just did the .47 coupling in my C22 preamp with some NOS sprague black beauties and my initial impression was WHAT HAVE I DONE!! when given a few hours run in they sound just lovely. My opinion only, after observation of course.
It's all part of a commie plot to sap and impurify our bodily fluids. |
| Woofer break burn in time? | promitheus | Multi-Way | 4 | 18th November 2003 12:42 PM |
