Originally posted by theAnonymous1
Hi James,
Here is a link to a somewhat confusing spec sheet for your pot.
http://avpg.business.t-online.de/PDF/RK16812MG.PDF
It has a pinout diagram, although a not so good one. Here is what I understand from the drawing.
This is with pins facing up and shaft toward you from left to right....
Pin1 : Dummy/No Contact
Pin2 : Out 1
Pin3 : Ground 1
Pin4 : Ground 2
Pin5 : Out 2
Pin6 : In 2
Pin7 : In 1
Pin8 : Dummy/No Contact
I really hope this is correct; because the pot I just purchased is the same thing only with 6 gangs instead of 2. That means I have 3 rows of 8 pins to deal with instead of 1.
Hope this helps.
Did you ever get the pinout confirmed for the RK16812MG? I have just ordered one but the details in the dustsheet are a bit weird....
TIA
Mike
