Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 10th June 2006, 06:47 PM   #1
Default 5 pin din to rca how to.
hello, i want to make my own 5 pin din to set of rca's that were used in the old school orion and ppi amps, here is the config of the 5 pin din. but i do not know where to connect to the rca's:
External 115VAC, 60 Hz line input, +/-12 VDC, 300 mA output power supply.
The 5-pin DIN output connector of the power supply provides:
Pin 1 COM
Pin 2 COM
Pin 3 5V (not used by xo/eq)
Pin 4 -12V/300mA
Pin 5 +12V/300mA
of course i was going to use the commons 1 and 2 per each rca outer jacket, but the pin 4, 5 do not if it should be on which side left or right or the rca's
i have couple pics but will not post.
Old 10th June 2006, 10:12 PM   #2
oPossum is offline oPossum  United States
oPossum's Avatar
Old PPI and Orion amps are:
1 -15 V
2 Gnd
3 +15 V
4 Right Audio
5 Left Audio
Pin order is 1 - 4 - 2 - 5 - 3 (to be consistant with 3 pin DIN)
Connect the common of left/right audio to the center pin of the DIN connector. The center conductor from the RCAs then connects to pins adjacent to the common. The outer 2 pins will be unused - make sure they don't touch the audio!
Possum - the other white meat
Page generated in 0.06085 seconds (69.42% PHP - 30.58% MySQL) with 10 queries
