Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 9th June 2006, 12:44 AM   #1
maurycy is offline maurycy  United States
Default Help me identify a transformer
I have a transformer that was pulled from working vintage Pioneer receiver (model SX-650). Unfortunately I have no idea what are its specs.
If anybody has any idea, without asking me to mess with the wires and electricity, on the specs, please let me know.
Trafo has the following numbers on it:
UT-1
ATT-303
0-BE11-XAU
Thanks,
Alex
Old 9th June 2006, 02:14 AM   #2
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
... how come you dont just hook it up and measure? you can get the VA rating off of the back of the amp....
Old 9th June 2006, 07:52 AM   #3
before you hook it up, connect each wire into a terminal block so you have no accidents.
Try to find the mains windings, nearest the middle usually.
If two then assume 110V each. If one, then arrange for 110V input until you KNOW for certain what it was built for (110V or 20V).
regards Andrew T.
Old 11th June 2006, 12:32 AM   #4
I guess I can measure the output on the transformer. I am complete noob so I figured, I will ask the question here before trying to mess with electricity.
I have four wires on one side which I think are the mains. They are brown, white and two blue wires. I will try to connect the transformer and test the output.
Thanks.
Old 11th June 2006, 06:54 AM   #5
could the wires be blue and grey/violet?
Wire a mains light bulb in series with the primary of the transformer.
Just in case it is faulty or that you connect the two primary tappings out of phase.
When the primaries are connected out of phase, the transformer only has the primary resistance against the mains voltage and will draw many kilowatts before burning out due to very rapid overheating.
regards Andrew T.
Help identify toroidal transformer ro345 Solid State 5 23rd January 2009 04:08 AM
Identify transformer VA, sec AV and amp tankienbeng Parts 6 27th August 2007 09:44 AM
Help Identify a Transformer juan_caliente Parts 10 9th June 2005 03:19 PM
Identify This.... EchoWars Solid State 6 2nd August 2003 12:24 PM
Page generated in 0.07848 seconds (75.73% PHP - 24.27% MySQL) with 11 queries
