Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 26th January 2008, 04:12 PM   #81
The P suffix is plastic molded DIP. He needs metal TO-99 can.
Old 26th January 2008, 09:50 PM   #82
mirlo is offline mirlo  United States
Default LME49710
I think it was the 5534 desired in the metal can. Single, not dual. THe LM4562 is dual. Maybe the single LME49710 would do it, but you'd have to be sure that the 5534 isn't used in some nonstandard way, with unusual compensation or other circuits used on the offset null pins or compensation pins.
LME49710 is at Digikey for $9.15 in the metal can package.
-- Mirlo
Old 27th January 2008, 03:06 AM   #83
Oops... you're right. D'oh!!
Old 28th January 2008, 04:24 PM   #84
jblmar is offline jblmar  United States
I was able to get the original replacement 5534. $7.50 USD each!! Had to buy 10!!
The Sound Technology 1701A uses quite a few of these so I'm set for life in that regard.
Ron
Old 31st January 2008, 03:16 AM   #85
tedr is offline tedr  United States
Default opamps for audio
In my book it counts for something when the opamp has been designed for audio use in the first place, which is the case with 5534/5532.
Precision DC performance that is needed for industrial and instrument work are irrelevant for audio.
AC characteristics that are meaningful for audio don't matter for insrument and industrial applications. If you are an instrument designer you look for instrumentation opamps not audio opamps. I think audio designers should do the same, chose a part that has been designed for audio.
There are some fine products from That Corporation like "Ingenius" and "Outsmarts" that feature important realworld specs like common mode rejection ratio, these are in stock with Mouser or Digikey, can't recall which, maybe both.
In general look for "audio" in the opamp product description. And I like the idea about socketing them for experimentation.
Ted
Old 29th March 2008, 02:05 PM   #86
law is offline law  Hong Kong
Default NE5532, NE5534 : worth what ?!
Any body help to source the 5534 metal can TO99 opamp ?
Old 29th March 2008, 02:24 PM   #87
Electrons are yellow and more is better!
peranders's Avatar
Why will not a DIL08 plastic do?
/Per-Anders (my first name) or P-A as my friends call me
Old 30th March 2008, 05:36 AM   #88
I was told that metal can to99 5534 sounds more detail and natural than plastic one. Is it ture ?
Old 30th March 2008, 06:20 AM   #89
peranders's Avatar
I'll doubt that very much. A rumour is a rumour.
Old 4th April 2011, 06:40 PM   #90
Just saw in a Hi End electronic magasine, that even the layaout is identical in all 5534 op amps, there are different equipment to produce them. So even the quality of the Mask that are used.The magasine made deeply tests about the performance of different manufacters 55434 and FAIRCHILD had clearly the lowest distortion and best performance, So it was recomended for their clients.
Texas Instrument was the worst, and PHilips in the middle. Just some information worth thinking of when dealing with multiple op amps i series, like in a Mixingconsole like the MCI JH600series etc.
The NE5534....misunderstood? TimA Solid State 102 8th December 2010 02:23 AM
NE5532 vs NE5534 rumblinbass Parts 9 14th December 2007 02:24 PM
NE5534 Compensation Cap EchoWars Solid State 17 3rd January 2006 11:46 PM
What is the purpose of NE5534 in this amp Gasho Solid State 12 11th April 2005 12:02 AM
Page generated in 0.09647 seconds (76.20% PHP - 23.80% MySQL) with 11 queries
