Go Back   Home > Forums > Design & Build > Parts
Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Thread Tools
Old 29th November 2002, 12:06 AM   #1
Default Sleep Timer
I was wondering if any of you knew how I could build a "sleep" timer like on those cheap clock radios, you push a button the radio comes on and in 1/2 hour it goes off again. I was thinking of using a standard AC mechanical timer (for lights, etc.) but the clicky noise is awful. So I was wondering if any of you electronic guru's could design a circuit that I would put together?
Thanks,
Lyle Gordon
Old 29th November 2002, 11:28 PM   #2
I want to build a sleep timer for a radio, that when a button is pushed it switches on a 110VAC current and then after a set amount of time (say 30 min) the voltage is switched off.
I was thinking of using this as a basis: http://www.qsl.net/7n3wvm/sleep_timer.html
And then using a optically isolated triac driver and a triac to switch the AC current with the out put from that circuit.
The problem is im not sure that is the best way to go about it nor do I know what type of triac and driver I should buy or if a normal relay would work.
BTW I will also be powering the circuit with a transformer from the AC current.
Old 8th December 2002, 02:51 AM   #3
CryingDragon
Guest
i've built a circuit that uses an IRF510 (commonly avaliable from radioshack) that when supplied with a momentairy positive input it will stay on for a period of time determend by either the value of a cap or resistor....if your intrested...i'm still working out the prototypes for a automatic stanbd shutoff for my amp
Thread Tools
First Timer needs help mgalvez Tubes / Valves 24 17th October 2007 10:34 PM
Which switch for sleep function on Amp6 rca9449 Class D 3 9th August 2007 08:11 PM
Need help with PIC timer. Tolik Parts 9 9th May 2007 10:02 PM
Tripath sleep/mute start up delay BWRX Class D 1 25th September 2005 08:45 PM
Warren 'I'll Sleep When I'm Dead' Zevon Netlist Music 0 16th September 2003 03:17 PM
Page generated in 0.08050108 seconds (78.05% PHP - 21.95% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
