| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I need to replace an SCR in a circuit (auto timing light) its a TO92 case so I was limited to what was available. Decided an equivalent was a Motorola BRY55-400 and this was available from my supplier The data sheet identifies it as a Silicon Controlled Rectifier yet when it arrived from the supplier it was invoiced as a TRIAC. What should I believe?
David L |
#2 |
diyAudio Moderator Emeritus
I would believe the datasheet over the invoice, but check the part to make sure.
Brian |
#3 |
Hi Wombat2
Motorola says it's an SCR in their data sheet http://www.ortodoxism.ro/datasheets/.../BRY55-400.pdf so you should be OK. Just out of curiosity, what was the part number of the failed one? Cheers Rob |
#4 |
FOR3G
David L |
| Need a Triac | zedrider | Parts | 1 | 28th September 2007 03:38 PM |
| How to measure a Triac with a multimeter? | Charles Hansen | Parts | 3 | 1st September 2005 02:25 AM |
| Triac regulator | fr0st | Parts | 2 | 19th November 2004 06:15 AM |
| Triac Question | vinay | Pass Labs | 8 | 26th August 2003 08:31 PM |
| triac's used as crowbar?? | hugobross | Solid State | 19 | 12th August 2002 04:02 PM |
| Page generated in 0.07470 seconds (71.76% PHP - 28.24% MySQL) with 10 queries |
