Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
what would you use as a bypass cap? auricap or russian PIO?
Old 5th June 2006, 01:30 PM   #1
jarthel is offline jarthel  Australia
Default what would you use as a bypass cap? auricap or russian PIO?
as title. thanks for the reply.
Old 5th June 2006, 02:16 PM   #2
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Default Re: what would you use as a bypass cap? auricap or russian PIO?
I prefer PIO;but-just as first setup;
but-only your ears can tell you what's better
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 5th June 2006, 02:29 PM   #3
kmj is offline kmj  Sweden
kmj's Avatar
And the russian PIOs look quite impressive
I'm going to use 4x30uF and 4x10uF (Russian PIO) in my aleph-pre when I get around to building it
.....Where the music comes to die.
Old 5th June 2006, 02:29 PM   #4
which bypass cap?
The one that bypasses an audio signal past an electrolytic, or the one that bypasses glitches from active devices to the PSU.
For the audio, most would recommend a polypropylene.
for the second a ceramic.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 5th June 2006, 03:06 PM   #5
if the amp is a tubed one, would the answer be the same?
thanks
Old 5th June 2006, 06:07 PM   #6
the choice of high voltage ceramic caps is quite restricted. But for glitch suppression they are virtually unbeatable.
However, in a tube amp, the glitches due to sudden current changes may be non existant. ClassAB tends to generate them rather more than sound transients.
regards Andrew T.
Old 5th June 2006, 06:40 PM   #7
bikehorn is offline bikehorn  Canada
bikehorn's Avatar
i use some 400 volt mylars i got from radio shack. gets the job done.
Old 5th June 2006, 06:53 PM   #8
Rtop84 is offline Rtop84  Poland
As bypass cap I use russian PIO and russian teflons. Tefon caps are much better for bypass. They gives very clear detailed and fast highs.
Best regards,
Rafal
Old 13th June 2006, 01:43 AM   #9
KBK is offline KBK  Canada
While I don't doubt the efficacy of using a bypass cap to bring about a change.. I have found that..after over 20 years of using diffreing levels and types of bypass caps thoughout the years: In conclusion, a single cap of high quality is far better, and far less damaging to the sonic integrety of a given PS or signal path. I know that such can be expensive to enact, but it gives, by far, the best result. The most honest result, one that is most in concert with the timber, harmonics and actual character (envelope) of the given signal.
What I mean is, no bypass caps of any kind, whatsoever. Single cap only, or multiples of that given type, in parallel. But the single is best.
Your mileage may vary.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
what would you use as a bypass cap? auricap or russian PIO?Hide this!Advertise here!
DynamiCap / Auricap gaincell Group Buys 6 6th March 2012 01:58 PM
Capacitors - Audionote & Auricap eeka chu Parts 1 22nd December 2004 06:32 AM
AuriCap Glass_painter Tubes / Valves 14 24th July 2003 06:19 PM
Auricap, Hovland or NO Cap?[Search for the Best Cap] Elso Kwak Solid State 8 16th May 2003 05:48 AM
Copyright ©1999-2017 diyAudio
