Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Follow up to cap sleeve thread,Wire color makes a diffrence!!
Old 28th November 2002, 10:35 AM   #11
UrSv is offline UrSv  Sweden
UrSv's Avatar
Originally posted by CryingDragon
And green is best for ground, It helps immensely in reducing ground loops because, as we all know then color green is very straight on the molecular level thus making the loops straight and thus eliminating them
Actually for the ground you must use a wire that has two colours which need to be complimentary to the plus and minus wire colours otherwise you will not be optimal for the return currents and imbalance will occur. Common mistake.
/UrSv
PS. Having a light in the enclosure can be very good but I once took a 100 W bulb and blinded my signal so that it actually never came out. Be careful and use just the right light intensity so that it is comfortable but not too bright for the electrons.
Old 28th November 2002, 10:53 AM   #12
Circlotron is offline Circlotron  Australia
Circlotron's Avatar
Best-ever T/S parameter spreadsheet.
http://www.diyaudio.com/forums/multi...tml#post353269
Old 28th November 2002, 11:16 AM   #13
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
I installed a lightbulb inside my amplifier and speaker cabinet so the electrons can see where they are going. The result is a much brighter sound
NO, NO, NO, you are just confusing them with all the different frequencies of light!
What you need is 3 tuneable lasers with light pipes surrounding each wire. This will allow you to tailor the frequency response of each laser to the exitation frequency of the colour of the sheath, causing the electrons in the sheath to bounce around madly. This will stop the needed electrons in the cable from getting into the insulation, and keep them on the right path.
However, this now means I have to use blue wire for my negative rails, as when I used black, the military surplus UV laser I used took out my amp, walls, and fence outside, as well as half the block!
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 28th November 2002, 11:26 AM   #14
Christer is offline Christer  Sweden
Default Re: NUTCRACKER - ME??
Originally posted by halojoy
Cotton can do for most of us.
The sound you get, is somewhat less plastic and more soft.
For REAL high end, with a smooth, warm and rich upper rolloff,
there is only one thing:
HAND-WOVEN NATURE SILK
No, no, silk is over-rated. Cotton is at least as good, but make
sure you get ecological cotton which is non-toxic, or the electrons
will show sub-optimal performance.
Old 28th November 2002, 11:51 PM   #15
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
Default Coloured Sonics.....
Dyes used to colour insulation affect the dielectric properties.
Different dielectric properties affect sonics.
Avoid dyes containing Cadmium.
Chromium dioxide pigment sounds good.
Eric.
Old 28th November 2002, 11:59 PM   #16
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default FOOLING AROUND.
Think none of them were seroius about this anyways.
Little do they know that chemicals do affect sonics as do plastic polymers in general.
They probably never heard about fluorines,they don't know about field effects,they are in general ignorant about anything.
But I forgive them,
Frank
Old 29th November 2002, 12:02 AM   #17
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
What about cables without insulation ? Do I have to shine a blue LED on them ?
It's only audio. Member of the non modular PCB design committee
Old 29th November 2002, 12:18 AM   #18
pinkmouse's Avatar
Just because we were having some fun doesn't require personal insults, Frank, I think an apology is in order...
Old 29th November 2002, 12:21 AM   #19
jean-paul's Avatar
How dare you to beg an apology from our Frank ?
Old 29th November 2002, 12:40 AM   #20
mrfeedback's Avatar
Default But I forgive them......Why ?.
and "None so blind as those that will not see" and "None so deaf as those who will not listen"
Idiots and stupidity
Eric.
Follow up to cap sleeve thread,Wire color makes a diffrence!!Hide this!Advertise here!
Bi wiring/single wire distortion thread jneutron Parts 85 4th January 2006 11:20 PM
Suggestion: "follow this thread" function tschrama Forum Problems 2 16th September 2003 09:29 PM
Follow up question (16-4 Gauge Speaker Wire) FrankRoss Everything Else 0 24th December 2001 07:06 PM
Copyright ©1999-2017 diyAudio
