Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 30th May 2006, 03:25 PM   #1
xplod1236's Avatar
Send a message via AIM to xplod1236
Unhappy Need to drop 12-14v to 8.5 at 6 amps
I need to make an 8.5v power supply which will provide ~6 amps. The input will be 12-14 volts from a car. What would be the best solution?
I was thinking about using a 7809 regulator, and feeding its output to a buffer (maybe OPA549). I know I said 8.5v and now I want to use 9, but i'm pretty sure that 9v wouldn't cause any problems. Is there a better/simpler way to do this?
Old 30th May 2006, 03:42 PM   #2
Bazukaz is offline Bazukaz  Lithuania
Send a message via ICQ to Bazukaz
There is another Chip , LM338 , which provides min. 5A and has adjustable output voltage.
Old 30th May 2006, 03:53 PM   #3
That is still over 30watts constant disippation. ie HOT!
Why not use a switcher?
LM2678 switcher
Old 30th May 2006, 04:02 PM   #4
xplod1236's Avatar
I want to keep this as simple as possible.
Old 30th May 2006, 04:14 PM   #5
N-Channel's Avatar
Send a message via AIM to N-Channel
Default SimpleSwitcher
Xplod-
That's why it is called the LM2678 SimpleSwitcher IC. In its simplest form, all that is required (besides the chip itself) for a complete cuircuit are a diode, coil and two caps. For the adjustable version (LM2678-ADJ), just add two resistors for setting the output voltage.
I have used the LM2678 for the past several years in a solar charge controller, and it works very well, with no RF hash, either. In testing my circuit, from no-load to full-load, the only time the chip got warm was when I touched it and it picked up the heat from my hand. Not too bad! The chip's relatively high switching frequency (260kHz) allows the use of small capacitors and magnetics to reduce the size of the overall circuit.
The datasheet is very comprehensive, and even shows how to select the inductor, caps and diode. Nuts-n-bolts procedures, and not too much abstract theory. Go to the link cliff suggests and download the datasheet, and you'll be suprised how easy it really is.
Hope this helps,
Steve
Old 31st May 2006, 01:34 AM   #6
clem_o is offline clem_o  Philippines
Keeping 30W of dissipation "cool" is not simple, go with the switcher.
Cheers!
Old 31st May 2006, 01:50 AM   #7
xplod1236's Avatar
Okay, I'll give it a try. Thanks for the suggestions.
Old 31st May 2006, 01:55 AM   #8
rpapps is offline rpapps  Antarctica
From the link given above, the maximum output current is 5 Amps.
Try this one instead.
http://www.national.com/pf//LM/LM2742.html
Cheers
Rob
Old 31st May 2006, 03:54 PM   #9
N-Channel's Avatar
Default 6 Amps
Xplod-
Braincramp on my part! I totally forgot about the 6A load you have, and the LM2678 is good for only 5A.
Rob,
Thanks for pointing out the 5A limitation. I have looked at the link provided. Question: Does this come in a PDIP pkg, or just a SMT pkg? SMT might make things a little more complicated for him.
Xplod-
One PWM chip that stands out is the TL494. You could use it to drive a BIG PNP transistor in a PWM fashion, and get good to excellent results, typically in the 70-90% efficiency range. Go to this link:
TL 494: http://www.onsemi.com/pub/Collateral/TL494-D.PDF
Check out Fig. 21 on p.11 of the TL494 Datasheet. Making the following changes to the circuit shown should yield your desired output:
1) Change the TIP32 (3A) to a bigger PNP unit, like a TIP36 (25A), thus meeting your current requirements;
2) Change the MR850 to a higher current schottky diode, like a MBR1645 or equivalent, thus also meeting your current requirements. Using a Schottky over a regular fast-recovery diode will boost efficienct by a couple of percentasge points;
3) Add a 6.2k W from pin 1 of the TL494 to
ground (this will change the output voltage from 5.0V to ~9.1V);
4) Change the 0.1W power resistor to 0.01W. This will keep the curren-limit feature from kicking in until ~9-10A, which should meet your current requirements, and;
5) Change the inductor's windings from #22 AWG to 3 strands of #20 enameled magner wire, wound tri-filar. Using several smaller wires will enable you to more easily wind the coil. Or, you can just find a 1.0mH coil rated at 10A.
That's it. This schematic is basically the same one used in most cellphone cigarette-lighter adapters, only scaled a little bit up.
Thoughts?
Steve
Do New JJ GZ34's have less B+ Drop? Trout Tubes / Valves 8 23rd October 2008 04:34 PM
ad845 drop in intense-tavda Digital Source 12 6th November 2007 08:23 AM
Drop resistor value Painkiller82 Chip Amps 56 6th October 2007 09:39 PM
Feedback resistors with 'drop-in' replacementop-amps homemade Parts 8 14th February 2007 02:32 AM
Anyone know of a drop in replacement for the PE 279-310? DJNUBZ Multi-Way 0 4th September 2003 11:21 PM
Page generated in 0.09353 seconds (83.10% PHP - 16.90% MySQL) with 10 queries
