| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Howdy, Anyone got a good way to mount motor run caps on top of a chassis. I want to stand them up so the terminals protrude underneath. Figured I would just drill holes for the terms to go thru the chassis, but have not devised a way to secure the capacitor. They do have the standard little lip. Thanks, Jay
"Make everything as simple as possible, but no simpler" Einstein |
#2 |
can you source the clamping bands of the correct diameter? The bands are quite thin steel (usually plated) and could be re-shaped slightly if not exactly right. If so, then clamp underneath the panel and glue the lugs to the underside, or bolt if the unsightly countersunk screwheads are not a problem.
regards Andrew T. |
| Size and source of mounting screws for Maxon ReMax motor | copydex | Analogue Source | 2 | 10th June 2009 12:16 PM |
| Looking for amp kit that runs on 12V (car battery) | maurycy | Chip Amps | 5 | 2nd October 2008 08:29 PM |
| Still tring to find a couple 100uf motor runs | audiobliss | Tubes / Valves | 16 | 12th August 2008 09:28 AM |
| OPA4228 runs hot | iron25 | Solid State | 2 | 1st July 2007 05:42 PM |
| Thorens motor runs backwards! | GhettoSQ | Analogue Source | 18 | 20th September 2006 04:56 AM |
| Page generated in 0.06217 seconds (72.18% PHP - 27.82% MySQL) with 10 queries |
