diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Parts (http://www.diyaudio.com/forums/parts/)
-   -   BNC Connectors (http://www.diyaudio.com/forums/parts/80468-bnc-connectors.html)
Noak 29th May 2006 06:50 AM
BNC Connectors
hi all,
I'm looking to change my CDP and DAC's Coaxial RCA connectors to BNC instead. However, I've found from Farnell that there's a variety of BNC for various Coaxial type.
Since I've little knowledge about Coaxial types, can anyone enlighten me on what's the norm for Coaxial types for BNC styled cables? Using as digital connect so it should be 75ohms termination, right?
What are the different types of coaxial for? Different frequency range?
Thanks in advance.
jleaman 29th May 2006 06:55 AM
Re: BNC Connectors
Originally posted by Noak
hi all,
Thanks in advance.
I think it all has to do with the cable. Most cd players that have digital out have both bnc and the rca out some even have the optical out. Im running both and i can't see the difference between either of them. ( have not tried the optical out yet )
pburke 30th May 2006 05:18 PM
for SPDIF, get a 75 ohm rated BCN jack that's insulated from the chassis. Make sure you got that on the receiving end as well - more important there than at the source.
run internal wiring in 75 ohm wiring as well, if the unit permits.
Peter
Resources saved on this page: MySQL 18.75%
