Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th May 2006, 10:43 AM   #1
Bobhof is offline Bobhof  South Africa
Default Very simple passive mixer driving me nuts. Please help.
Hi all,
I am trying to make a simple passive mixer to sum the outputs from my computer (minijack) and my DVD player (RCA out) and send them into my sub (RCA inputs). I also need the output to be cut off when I plug my headphones into to a switched jack. Diagram is attached.
Here's the problem: it works perfectly when going out to the sub (whether I plug the sub into the RCA or the jack out) but when I plug in my headphones the sound is hardly audible. I have tried various phones with the same effect. It's driving me nuts! Surely if there is sound coming out it should work for either headphones or the amp?
Any help would be greatly appreciated.
Rob
Old 28th May 2006, 11:34 AM   #2
You are trying to feed your headphone through 10K resistors, correct? This might attenuate the signal to much for 32 Ohm or even 150 Ohm headphones...
Old 28th May 2006, 12:11 PM   #3
Yeah, but the level is fine when going to the amp. Should I just remove the resistors or do I need them? Sorry, really don't know much about this stuff.
Old 28th May 2006, 01:53 PM   #4
lndm is offline lndm  Australia
The amp will have a relatively high input impedance. The 10k resistors will not be significant here, they will be significant to the headphones.
Old 28th May 2006, 03:08 PM   #5
I see. Is there any reason not to take the resistors out of the circuit? I just put them there because I read that that was how to sum inputs.
Old 28th May 2006, 03:33 PM   #6
Yes, you need those 10K resistors for the mixing. But nor the RCA output of a DVD nor the line out of a PC is meant to be used for a headphone. You need a headphone amp for that.
Old 28th May 2006, 04:47 PM   #7
But the line out from my pc is a headphone out. Works fine if I plug the phones into my pc. What do you think I should do?
Old 28th May 2006, 07:06 PM   #8
replace the 10K with 470 Ohm and see if that helps...but it might be that the dvd RCA output will not be suiteble for driving a headphone...
gl,
Thijs
Old 28th May 2006, 07:47 PM   #9
Thanks for all your help.
Old 28th May 2006, 09:58 PM   #10
You really need an amplifier to feed the headphones, what you're trying to do is WRONG - which is why it doesn't work!.
Nigel Goodwin
Need a Passive Mixer Circuit that allows for disconnected sources azira Analog Line Level 1 19th April 2008 10:44 AM
simple amp, PNP driving PNP pairs wleediy Solid State 0 8th July 2007 11:23 PM
simple 2->1 mixer amacks Parts 3 14th May 2007 09:31 PM
some dumb questions that are driving me nuts slackerbob Multi-Way 3 8th August 2003 10:24 AM
simple line mixer JAZZ2250 Parts 8 18th January 2003 04:57 PM
Page generated in 0.09239 seconds (76.79% PHP - 23.21% MySQL) with 11 queries
