Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 28th May 2006, 09:45 PM   #11
Bobhof is offline Bobhof  South Africa
Thanks Nigel. I understand now why it is WRONG. However, my headphones do work just fine straight out of the computer without an amp so I have just modified my design to put the switched jack before the mixer. Now, when I plug in the phones it cuts the computer output to the amp. The DVD player bypasses the headphone jack so DVD output is not affected when headphones are plugged in (ie I can listen either to computer output on headphones or a mix of computer and DVD through amp). Seems to work fine and no need to add another component (also works without power).
Thanks again to all who helped.
Old 28th May 2006, 10:20 PM   #12
lndm is offline lndm  Australia
You want both inputs at once and that's the thing. You want a mixing stage but it needs to be a stage that can supply power output. It should be active. You might look at buffers. For something simple, just connect the headphones through an existing stereo amp.
Need a Passive Mixer Circuit that allows for disconnected sources azira Analog Line Level 1 19th April 2008 09:44 AM
simple amp, PNP driving PNP pairs wleediy Solid State 0 8th July 2007 10:23 PM
simple 2->1 mixer amacks Parts 3 14th May 2007 08:31 PM
some dumb questions that are driving me nuts slackerbob Multi-Way 3 8th August 2003 09:24 AM
simple line mixer JAZZ2250 Parts 8 18th January 2003 03:57 PM
Page generated in 0.06162 seconds (70.57% PHP - 29.43% MySQL) with 11 queries
