Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th May 2006, 10:15 PM   #1
Default Solder Paste Question
I purchased some solder paste /flux to use to help me the solder flow for hot tinning some PCBs I'm etching.
There is no information on the container other than "solder paste". It there a way to tell via some test etc if this is the electronic flux or the plumbing flux?
Old 25th May 2006, 11:05 PM   #2
poobah is offline poobah  United States
poobah's Avatar
Don't use it if you don't know EXACTLY what it is...
Paste fluxes are generally used for plumbing. In electronics they show up in solder / flux paste formulas used for reflow soldering SMT parts.
Kester #331 is a nice liquid flux that will work well. It also washes off nicely with hot water and doesn't pollute.
Old 26th May 2006, 07:23 AM   #3
solder paste and flux paste are two completely different products.
Solder paste is a flux with solder powder incorporated.
However, you do need to check what kind of flux and it's compatability with electronic circuit boards.
regards Andrew T.
Old 26th May 2006, 07:34 PM   #4
artz is offline artz  United Kingdom
Default solder paste
Hi Im new to the forums but iam a surface mount engineer and i know a bit about solder paste . Does it have a name? if it does i can probably tell you what it is ie is it Alpha/fry/indium or such like?
What brand of solder paste? G Digital Line Level 5 2nd March 2009 11:25 PM
DIY paste mask for SMD PCB fab mobyd Parts 1 23rd January 2009 10:42 PM
Solder Mask pattern question NorCalAudio Parts 2 2nd November 2008 08:50 PM
A Question about using resincore solder bulgin Equipment & Tools 3 7th December 2006 12:15 AM
jpg. pics too large to paste richwalters Everything Else 6 17th November 2006 03:25 AM
Page generated in 0.07304 seconds (70.39% PHP - 29.61% MySQL) with 10 queries
