Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 25th May 2006, 03:04 PM   #1
analog_sa's Avatar
Default Any info on 2SC5929?
Just basic parameters will be great. Many thanks.
Old 25th May 2006, 03:17 PM   #2
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Well, I can tell by the C in the number that it's NPN.
Also, it is a power transistor by the number.
The closest data I can find is 2SC5926, which is NPN power of some sort. Unfortunately, I'm at a venue computer kiosk with no pdf viewing support so I can't actually read the datasheet.
I'll bet that this may be a switching transistor?
Other people will know anyway.
-- Duo, W1ngs, VA7MON, and lesser known handles. --
-- http://www.w1ngselectronics.com -- My Work and Projects --
Old 25th May 2006, 03:48 PM   #3
analog_sa's Avatar
Thanks Duo
The best i could find was c5926 as well. The 5929 is a horisontal deflection tr in an HP monitor. The owner/repairer is in Mozambique so i'm a bit cautious about making any rash suggestions
Old 25th May 2006, 04:36 PM   #4
Duo's Avatar
Alright, well if it's the H defl from the monitor, you'll find a rather high Vceo, sometimes over 500V. Probably a similar or slightly higher Vcbo. The current would come to maybe 7 to 15 amps... Hard to say.
fT should be fairly high, being that it's used in a fast application, at least over a few MHz.
It definitely won't be the most linear thing sround, though I've used them in audio output stages with good results as long as the feedback in that stage is designed well to cope with non-linearity. Generally it's nicer to use these for high voltage low current so that the gain stays somewhat still. Or class A with constant current, thus the gain will stay much more on the ball.
If you cascode them, with constant current, you should be able to make a class A output that's really flat I suppose, but hard to say.
What are you using this one for?
Old 25th May 2006, 04:56 PM   #5
analog_sa's Avatar
Nothing to do with audio. Just trying to suggest a replacement for the repair. If it was mine i'd stick the first BU that can take 600v and 15A and pray it works.
Old 26th May 2006, 01:32 AM   #6
Duo's Avatar
I'd say that the most important thing here is to figure out if your transistor has an internal damper diode, or not.
If it does, you need to put in a replacement that has one, otherwise it'll fry itself rather quickly. To check for that, you have to see if there's a somewhat hefty looking diode connected between collector and emitter of the transistor. For this type, that's the second(collector), and third(emitter) pins as you face the transistor and count from the left.
If the board already has one, then don't worry about it too much. If it isn't there, then you need to find a replacement with the diode inside or do some homebrew modification by adding your own diode, which I don't recomend.
I'll stay posted to see your progress.
Old 26th May 2006, 07:19 AM   #7
How are you arriving at the conclusion that this is a high power device?
We know it is NPN and that it is modern, but as for the rest. Where is it coming from?
regards Andrew T.
Old 26th May 2006, 04:42 PM   #8
The part number is Matsushita/Panasonic.
It is likely that no datasheet has ever been published in English.
Need info on my Onkyo, can't find any info anywhere. gixxierific Digital Source 0 19th April 2009 03:49 PM
How to get cathode bias info from grid bias info? leadbelly Tubes / Valves 8 14th August 2008 04:40 PM
Got info?! looking 4 info on the BG Neo 10 gp4Jesus Planars & Exotics 1 18th November 2006 03:14 AM
info diegolin Solid State 1 18th January 2006 10:07 PM
Page generated in 0.09088 seconds (77.07% PHP - 22.93% MySQL) with 10 queries
