Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st May 2006, 02:42 PM   #1
Send a message via MSN to youyoung21147
Question Active filter question
I'm currently designing my first active filter and I've seen on ESP website that a bandpass filter needs one section for the highpass and another one for the lowpass.
It means 4 opamps in series for a 24dB/oct bandpass filter ! Really not nice IMHO
So I'm wondering if it is possible to put the highpass and lowpass sections on the same opamp.
Is it possible ?
BTW : is it cleaner (sound meaning) to use a discrete transistor (eg. BC560C) or an opamp (eg NE5534) for active filtering ?
Thx in advance !
Old 21st May 2006, 03:46 PM   #2
adolphe is offline adolphe  Canada
There's several opamp packages available that have 2 or 4 opamps on a single chip. You could use one of those to save space.
-Scott
Old 21st May 2006, 04:47 PM   #3
joensd is offline joensd  Germany
A bandpass of a 4th order is usually realized with two opamps.
What you do is basically cascade two 2nd order bandpasses.
Canīt seem to find a nice link that shows how itīs done.
Admittedly calculating filter components can get a bit complicated,
so maybe you should get yourself a filter program.
TI filter pro
Itīs been a while but I installed the freeware filter program from Texas Instruments at one point and liked it very much.
Iīd start from there.
Rod cascades highpass and lowpass to achieve bandpass which is too much parts indeed.
If you want to go discrete you can also make passive filters of max. 2nd order, buffer them and follow with another passive filter.
For a bandpass Iīd use an opamp though.
discrete active XO
jens
Old 21st May 2006, 05:27 PM   #4
-Scott
Thanks for the suggestion, but I was speaking of sound issues : 4 components in series are never good. Place for me is never a problem
That's why I want to put the components of the lowpass and highpass on the same opamp
Canīt seem to find a nice link that shows how itīs done.Admittedly calculating filter components can get a bit complicated,
TI filter pro
I have FilterPro but I prefer using this online design tool : http://www.analog.com/Analog_Root/st...er/filter.html
It proposes bandpass but strangely, it doesn't allow to adjust separately the two cutoff frequencies.
In fact, what I'd like to know is if the schematic of the bandpass filter shown can be used with the same components values as if I used two different sections.
Concerning discrete I was only considering it if it gave a better/more transparent sound than opamp. But for a 1st project, I'll stick with opamps
Thanks for the answers !
Question about active filter noise sol Solid State 2 17th August 2006 05:59 AM
active filter question jimbo1968 Multi-Way 3 6th February 2006 08:36 PM
Noob question : what exactly is the "Q" of an active filter ? youyoung21147 Chip Amps 7 10th December 2005 09:39 PM
active filter from rod elliot and sub filter questions wuffer Parts 0 2nd October 2005 01:12 PM
Active Filter - GvT GvTT Solid State 0 3rd February 2004 09:31 AM
Page generated in 0.08023 seconds (75.13% PHP - 24.87% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
