| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
can someone tell me why i cant/shouldnt do this ?
i want to make a +/-vdc supply but do not have the center-tapped xformer that would be ideal. so why cant i parallel 2 rectifiers in-phase and series their +/-vdc outputs then feed a pair of series-caps the +/-vdc from the rectifiers ? the ground reference would be the series-point of the rectifiers and the series-point of the caps. thanks.
if it aint broke.........tweak it !! |
#2 |
It must be done the right way or you will inadvertently short your winding. The closest good thing I can think of is the voltage doubler.
http://hyperphysics.phy-astr.gsu.edu...c/voldoub.html for example. |
#3 |
dont understand why/how the windings might get shorted.
i know i did this once before a long time ago and it worked but i either had to reverse the polarity of the ac at 1 of the rectifiers or i had to keep the same polarity at both rectifiers i dont remember exactly which way it was. i do remember that 1 of the ways the xformer started to buzz loudly and i had to disconnect immediately. can you tell me how i might *inadvertently* short the windings ? arent the xformer windings being isolated by the rectifiers ? might try it today with a cheapy wallwart and see what happens.
#4 |
If you build a standard voltage doubler, you'll have no problem. The way you described it, I imagined this (ignore the dots):
____D__ (\ (..\ (...D (___\___ | | | |______ With limited info it was a wild guess. |
#5 |
| DAC 1955 paralleled | fabiodord | Digital Source | 9 | 25th September 2008 10:20 PM |
| 3 paralleled opa541's | odysseybmx414 | Chip Amps | 1 | 11th May 2005 01:37 PM |
| Paralleled Toroids? | theAnonymous1 | Solid State | 5 | 19th July 2004 02:40 AM |
| DAC with paralleled TDA1541's | sugano | Digital Source | 0 | 2nd May 2003 08:14 AM |
| Zen v4 with paralleled FETs | Stanislav | Pass Labs | 15 | 4th March 2003 10:48 AM |
| Page generated in 0.08115 seconds (74.08% PHP - 25.92% MySQL) with 10 queries |
