Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
metallized caps instead of electrolytics in a tube rectifier power supply?
Old 21st May 2006, 01:49 PM   #11
phn is offline phn  Sweden
phn's Avatar
Just the thread I needed.
I'm working on a PSU and didn't know if I could use a nonpolar (ASC-type) cap. Does that mean that a nonpolar cap can be used in place of a polarized one in general, but not the other way around?
Old 21st May 2006, 02:01 PM   #12
lndm is offline lndm  Australia
Yes.
Old 21st May 2006, 02:02 PM   #13
jarthel is offline jarthel  Australia
Originally posted by lndm
AFAIK, they will offer similar advantages, partly because AFAIK, they are polypropylene in oil. No doubt these are made for heavy current, but the motor runs I have dissected used foil, not metallised film. Still though, I have heard others speak highly of ASC caps.
I would think ASC would be heaps better than what you can get from the local jaycar store
Old 21st May 2006, 02:15 PM   #14
From what I've heard, you're probably right.
Old 21st May 2006, 07:15 PM   #15
phn's Avatar
lndm, thanks. Now I have some electrolytics to ditch.
Old 26th May 2006, 04:46 PM   #16
kevinkr's Avatar
I use ASC polypro in oil motor runs in my newest amplifier design, and have long used Solen films in high voltage supplies. Not only have I found in many instances that they sound better than electrolytics, but their service lives should be much longer as well. I have not had to replace a film cap yet, but in some instances have been through several rounds of EL replacements.
The one disadvantage of course is the huge size.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
metallized caps instead of electrolytics in a tube rectifier power supply?Hide this!Advertise here!
Gas-Rectifier power supply bogdan_borko Tubes / Valves 15 14th October 2012 08:13 AM
external power supply, rectifier in or out? poolorpond Power Supplies 26 28th November 2011 05:13 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Recommendations on removing electrolytics from power supply luvdunhill Parts 11 9th August 2007 04:19 PM
Question about tube amp power supply caps gjo Tubes / Valves 12 26th March 2006 11:47 PM
