| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
This is a surplus part I came across whilst polishing the bottoms of my shoes...
A Raytheon "Driver Transformer". It's about a 1.5 inch square sealed cube, 6 pins, labeled: DRIVER TRANS 292-4278G1 1-2-3 14V CT 4-5 28V RMS 10MA (#6 is core ground) 380-240~ WV40 MAX ALT 60,000 FT RATHEON MFG. CO. WALTHAM, MASS. What is it used for??...What can it be used for?? I am confused by the pin #'s.....the primaries are usually #'s 1,2,3......or is this just a simple 28v to 14v ct , with unstandard pin numbering??? =RR= ------------------ |
#2 |
Hi redrabbit
It sounds like a single ended to push-pull coupling transformer for a tube circuit. The puzzling aspect is the 380-240~ marking which suggests a frequency range, the ~ being the old symbol for Cycles (Hz in todays language). As such it would not be much use for audio. Sorry, can't offer any more insight. Cheers Rob |
| FS: 6B4 NOS Raytheon tubes | Jimmy D. | Swap Meet | 0 | 1st December 2008 01:59 AM |
| Help need some info on this Raytheon | impsick | Tubes / Valves | 5 | 27th July 2008 05:28 PM |
