Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 17th May 2006, 02:51 PM   #1
Send a message via ICQ to ackcheng
Default HPHV shunt regulator discussion
While I am searching for a good circuit for tube preamp, I came across Allen Wright's design and also bought his book about super regulator which happens to be a shunt regulator. Then further searching on the web leads me to here
www.euronet.nl/~aespreng/Shuntregv11d/Manual.pdf
A very well organised and describtive manuel on HPHV shunt regulator which also uses the same idea as Allen's super reg
I wonder if anyone had built this before and have any comment on it? I am ready to build one myself. My question is that whether it is possible to modify the circuit to produce 4A at 550V
I noticed that IRF830 has a capacity of 4.5A
Should I reduce R6 to 0.5R, then the max current for the CCS should increse to 2.5v/0.5R = 5A? Would this work if I use a huge heatsink?
ackcheng
Old 17th May 2006, 02:58 PM   #2
A few more questions
1. Can I parallel a few more IRF830 to get a higher current in the CCS part?
2. Can I parallel a few more IRF830 to get a higher current in the shunt part without using tube to increase the shunt current?
Old 18th May 2006, 01:48 PM   #3
Sorry, Current and voltage requirement should actually be
170V / 4A
HPHV regulator, designed by Emile Sprenger djn111 Tubes / Valves 5 23rd January 2009 12:24 PM
HPHV regulator measurement ackcheng Tubes / Valves 3 18th September 2006 06:44 PM
HPHV regulator ackcheng Tubes / Valves 9 19th May 2006 03:19 PM
Page generated in 0.07494 seconds (71.52% PHP - 28.48% MySQL) with 10 queries
