Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 16th May 2006, 07:56 PM   #1
mpmarino's Avatar
Default Odd toroid and odd issue...help...please!!
I have literally stolen a couple of 1kva potted center Amveco toroids. The problem is as follows:
The label states the windings are <primary- 2*32v> and <secondary-120v>..this is not a typo. I believe these to originally be for some type of solar powered rectifier.
I applied 14v ac using a small trafo I had on hand to one of the primaries and had ~55v ac on the secondary. OK, now I am sure what winding is what. By the way, the 120v winding measured anywhere between .2 to .6R depending on which way the wind blows
Is it possible to run a toriod reversed. Can I run a secondary as a primary and vice versa? When I apply 120v to the 120v secondary I get a small explosion I have played with resistors on that 120v winding and managed to see 32v on the 32v winding but as soon as I do a live bypass to the resistor I get another small explosion
Are toriods different than EI in this respect?
Crazy Yankee.
Old 16th May 2006, 08:41 PM   #2
anatech is offline anatech  Canada
anatech's Avatar
Hi mpmarino,
One wonders if these aren't meant to deal with a square wave. Something like a Carver Mag coil. The direction wouldn't matter.
I bet the same thing happens if you feed 32 Vac sinewave into a primary winding.
-Chris
Old 16th May 2006, 11:27 PM   #3
mpmarino's Avatar
Thanks,
The label also indidates 60Hz.....
Could the inrush be so high it is just appearing like a short? ,,, I have yet to try a lightbulb in series.
on the 32v idea:
I've got 32vac kicking round here somewhere..I'll try that too.
Crazy Yankee.
Old 16th May 2006, 11:36 PM   #4
anatech's Avatar
Hi mpmarino,
Carver Mag coils are 60 Hz. Waveform is everything. It's saturating with a sine wave input.
If you were to use a variac, you may find the current rising to a high level at only 40 ~ 60 Vac. Use one of your amps to feed the transformer with a square wave. That might still draw too much.
Have you ever looked at an inverter waveform for an inverter? It's basically a low duty cycle rectangular wave. Very approximately the rms value of a sine wave.
-Chris
Old 16th May 2006, 11:45 PM   #5
mpmarino's Avatar
Thanks!
Yes, I see your point..makes sense.
I just want you to be wrong
Crazy Yankee.
Old 16th May 2006, 11:49 PM   #6
anatech's Avatar
I can understand that. I do too, for your sake.
-Chris
Old 16th May 2006, 11:53 PM   #7
mpmarino's Avatar
...but, in the meantime, what the ---- is a Carver Mag coil ????
Crazy Yankee.
Old 17th May 2006, 12:13 AM   #8
anatech's Avatar
It's a little metal thing that looks exactly like a power transformer, but with vastly different characteristics. It saturates easly when presented with a sine wave. Many techs like to short out the triac "switch" to test them on the bench. That way they can force the amp on. Well of course, it draws a ton of current and blows the fuse if they are lucky. Sometimes the caps and things explode since the voltage rails just went wayyyy high.
The mag coil wants to see a variable phase chopped AC waveform just like a triac dimmer. Except it's also really picky about the net DC being zero. Otherwise we are back to high current draw. The operating principle is current. Current in, current out. It's smaller than an equivalent transformer.
-Chris
Old 17th May 2006, 12:44 AM   #9
mpmarino's Avatar
Ah I see. Sooo I'll just stick an electric heat triac T-stat or a high powered dimmer in front of it and I'll be all set.
Just kidding.... but who knows!
Crazy Yankee.
Old 17th May 2006, 04:47 AM   #10
mpmarino's Avatar
Your right on the money Chris. The 32v taps do the same thing. They are useless lumps.
Hey, at least the copper is worth something! Maybe I can do something with the cores.....Blahhhh!
Thanks for your help!
Marc
Crazy Yankee.
Hum issue e_fortier Class D 6 3rd March 2009 02:42 AM
Help With TLB / Amp Issue Forster Multi-Way 0 2nd May 2007 07:51 PM
Trade a 40V 400VA Toroid for 20V 300VA Toroid john65b Swap Meet 7 10th October 2006 03:49 AM
Amp and Sub issue AudioMistake Car Audio 1 26th June 2005 08:59 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
