Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 15th May 2006, 03:32 PM   #1
Default Modify soundcard, unbalanced to balanced.
I'm thinking of modifying my soundcard, an M-Audio Revolution. I'm thinking about adding balanced outs for the front channels.
I've just built myself a pair of Aleph 5 monoblocks and they have two inputs. Rca and xlr. I drive these directly from the soundcard at the moment. But now I want to connect other equipment to it as well as the pc. I'm aware of wires that go from rca to xlr, but this is without the benefit of balanced transmission of course. The monoblocks might be placed some distance away from the pc so having balanced might be a good thing.
Is this a bad idea? Will I degrade the sound by converting from unbalanced to balanced?
Old 15th May 2006, 03:52 PM   #2
Did it Himself
richie00boy's Avatar
You need to build a little converter box. Look on sound.westhost.com there is a project on there and also the power supply you will need is P05 powered from a 'wall wart' to give you an isolated supply.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 15th May 2006, 04:32 PM   #3
Thanks for the reply. I was already looking at those projects. Will adding this circuit degrade the signal though? At any level I'm able to hear?
Old 15th May 2006, 05:31 PM   #4
Did it Himself
I'm sure some will say it will. I feel the benefits when using longer cable runs far outweigh any claimed sonic smearing.
Old 15th May 2006, 05:54 PM   #5
Thanks. Just what I wanted to hear.
Old 15th May 2006, 11:44 PM   #6
Get a pair of SSM2142 (Analog Devices), or DRV134 (Burr Brown).
They are pin and package interchangeable. These guys are
designed specifically for driving a balanced line. Just add
power supply decoupling caps and XLRs.
You can also modify equipment at the receiver with the
SSM2143 / DRV135. If you use the driver / receiver pair, you will
get exceptionally good performance.
-- Jim
Old 16th May 2006, 03:12 PM   #7
-- Jim
Thanks for the tip. They look nice indeed, and easier to implement(me be lazy). But I don't need a reciever with my aleph do I? Or have I misunderstood once again..
Modify Soundcard Help Needed ! rs_av_solutions Digital Source 0 29th December 2007 12:14 PM
Unbalanced to Balanced mcash257 Parts 3 14th October 2004 12:03 AM
unbalanced/balanced/unbalanced conversion using transformers vladimir Solid State 10 27th February 2003 06:54 PM
unbalanced or balanced theturtle Everything Else 4 5th January 2003 04:52 PM
Zen Balanced Line Stage Balanced vs Unbalanced macka Pass Labs 28 11th December 2002 06:18 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
