Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 18th May 2006, 05:00 AM   #11
Look in the hardware store. it's used to clean walls before painting.
Remember when detergents were sold and advertised as "contains no phosphates"?
Well, it ain't that kinda' party.
Old 18th May 2006, 05:39 AM   #12
redrabbit's Avatar
An autobody /auto paint supply store will carry an already diluted - ready to go solution. Or a well stocked general paint store.
If you do go to a chemical supply, you won't need much. It's possible they sell pre-dilluted stuff. I'm not sure , I think it's 10-20% acid ---->to the water, brushed on, kept wet (keep re-brushing) for about 5 minutes, rinsed thoroughly. You will know it has been etched when the water no longer "beads" on the metal.
Always pour acid into water...not the other way around.
Why?? not sure, I assume that having full strength acid out in the open is just too dangerous, but when adding acid to the water, it is instantly dilluted, and therefore safer to work around.
=RR=
Old 18th May 2006, 05:56 AM   #13
sklimek is offline sklimek  United States
sklimek's Avatar
=RR=
"Always pour acid into water, as the reverse could cause a cloud of dangerous fumes to immediately bubble up"
Quoted from a printmaking lab on using nitric acid for etching zinc plates.
I suppose if you are clumsy and pour the water into the acid to quickly it could splash out and start etching your flesh as well.
Stan
Old 18th May 2006, 08:36 AM   #14
Tweeker is offline Tweeker  United States
There is a high chance of spatter when pouring water into acid.
Be sure your foil hat has a good low impedance ground.
Old 18th May 2006, 11:03 AM   #15
You really shoulda oughta pour the acid in the watah...
Chem 100
Aluminium vs steel chassis Rob11966 Tubes / Valves 86 22nd January 2009 04:45 PM
DIY Steel Chassis GlidingDutchman Everything Else 4 2nd August 2008 07:11 AM
Paint steel chassis with the "aluminum paint" used on wire fence? vax9000 Tubes / Valves 2 23rd July 2006 01:14 AM
A possible good source for steel chassis Witchdoctor Tubes / Valves 1 12th January 2006 04:39 AM
using steel chassis as ground franjy Parts 4 23rd March 2005 08:24 PM
Page generated in 0.07592 seconds (75.18% PHP - 24.82% MySQL) with 10 queries
