| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Could someone recommend the Lundahl line input transformer equivalent to the
Jensen JT-11P-1 AND CineMag CMMI-15/15B line input transformers. I added a link to Lundhal and Jensen: http://www.jensen-transformers.com/datashts/11p1.pdf http://www.kandkaudio.com/transformers.html I need to get two of these transformers and I'm having trouble comparing the specs for the Lundhal for comparative info. Thanx - Stan |
#2 |
The most closely matched transformer in the Lundahl line from an impedance standpoint is the LL1540. If you don't need the relatively high impedance service, there are a host of others that will do as well, many at higher maximum signal levels.
#3 | |
Stan |
#4 |
Stan,
What is the output impedance of the source driving the amplifier? There may be a better transformer for your application than the LL1540, depending on what it is. If you used the L1540 you may benefit from the terminating resistors. If you are installing the transformers in the amplifier, you could split your 100K input resistor into two series connected 50K resistors and then these would effectively take the position of the "R/2" resistors in the diagram. |
#5 | |
#6 |
I wasn't clear. I was interested in knowing what the output impedance of your preamp that is driving your amplifier is.
#7 | |
http://digilander.libero.it/paeng/a_...ine_preamp.htm And a couple of Russian data shts for the 6H30: http://headwize.com/images3/6h30a.gif http://headwize.com/images3/6h30b.gif Helpful? |
#8 |
This preamp has a low enough impedance for a variety of transformers. The most sonically transparent of the choices is the LL1690, but the LL1540 will work, too.
#9 | |
BTW – here is a schem that uses your product as a power supply for the 6H30 that I’ll eventually get to as well. Stan |
#10 |
Hi!
Can someone tell me how much inductance has the LL1540? Tyimo |
| Jensen JT-11P-1 Line Input Transformer | csrote | Analog Line Level | 0 | 13th December 2008 09:40 PM |
| PCB mount line input transformer question | audiowize | Tubes / Valves | 0 | 11th July 2008 07:05 PM |
| Line output as line input transformer? | bambadoo | Tubes / Valves | 7 | 22nd January 2008 06:44 AM |
| Line input transformer for unbalanced to balanced conversion | okapi | Chip Amps | 23 | 12th January 2008 05:29 PM |
| need input on SS buffer w/transformer line amp. | AudioGeek | Solid State | 0 | 17th January 2005 08:23 PM |
| Page generated in 0.11019 seconds (79.73% PHP - 20.27% MySQL) with 11 queries |
