| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi All.
Dose anyone out there know anything about the pictured Stark VT-9 multimeter. I can figure out the AC/DC/R functions well enough - its the alleged capacitance and inductance measurements that have me mystified. Any suggestions from you retired(?) technicians would be very helpful indeed. Thanks to all Jess
#2 |
Hey Jess,
I have a VT-9 also! I've had it for years (since my teens - that's a long time). I never did find out anything as Stark information is hard to come by. You just reminded me I still had it. -Chris |
#3 | |
Well, I guess if no one has a manual, I will just have to trace the cct and draw it up so that one of the wizards out there can lett us how to use the dratted thing! Mine works beautifully for AC/DC/R - checked against my DVM it is as accurate as any analog meter I've ever seen. And that huge meter - just georgeous. As I said before, I want to learn how to make inductance measurements. And, how does one use the db scale(s) on the bottom of the meter face? Cheers Jess |
#4 |
Hi Jess,
The dB scale is used the same as your AC meter. Just read the scale directly. It assumes you are across a 600 ohm line for dBm. It tells you what AC range to be one if you look carefully. -Chris |
#5 |
Hi Chris:
Now, that's why I love this forrum so much - just ask and someone will know the answer Of course, it helps if I have the background to understand the answer [I]"assumes you are across a 600 ohm line for dBm"[I] Is db used to measure relative signal strength? Like, can it be used to measure the gain of a preamp in db? Jess |
#6 |
Hi Jess,
A diagram won't help much. dB ratings are power measurements and are assumed to be across a 600 ohm load (resistor for example). Changing the load impedance changes the power dissipated in the load. These days in the audio field we use dBu. It's the same except that we ignore the impedance and refer the measurement to a voltage only. Your old scale was referrenced to 0.775 V across 600 ohms. This link http://en.wikipedia.org/wiki/Decibels should help you understand it a little better. -Chris |
#7 | |
Hi Jess,
-Chris |
#8 |
Chris:
The wiki page will absorb my brain for a day or two... Thanks for the guidance. I am looking forward to this Jess |
#9 |
The link doesn't work
#10 |
Speakerholic
Works fine for me.
| stark and ciare CH250's in toronto | smak | Swap Meet | 8 | 23rd March 2011 06:24 PM |
| how to make this esr meter work with 250uA Panel meter | dytln_02 | Everything Else | 2 | 27th January 2007 10:13 PM |
| inductance meter from a cheap meter? | jarthel | Parts | 3 | 22nd September 2006 05:37 AM |
| Making a milliAmp meter, become a Volt meter | redrabbit | Power Supplies | 11 | 26th May 2006 07:51 PM |
| t-amp vu meter and volt meter question.... | rectaacies | Class D | 7 | 3rd February 2006 11:22 AM |
| Page generated in 0.10088 seconds (79.18% PHP - 20.82% MySQL) with 10 queries |
