Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 5th May 2006, 11:07 AM   #1
Default This soldering station OK for smd?
http://cgi.ebay.co.uk/Good-quality-s...QQcmdZViewItem
It's about all I can afford right now without reducing the budget for a scope, probes, some 41hz kits and a few extra components.
He also sells the horses hoof type tip that is recommended for smd work.
http://cgi.ebay.co.uk/spare-solderin...QQcmdZViewItem
Good enough for a year or two or a waste of money?
Old 5th May 2006, 04:18 PM   #2
It looks alright to me but it depends on what you’re soldering and how much experience you have. Just about any temperature controlled iron with a reasonably fine tip is okay for larger surface mount parts such as SO-packaged active devices and 1206 & 0805 passives. Only TQFPs and other really fine-pitched parts need special tools, IMO.
I’d also recommend some SM tweezers as they make handling the dinky parts much easier. I use this type with the flat tip but the normal hair removal type might work okay:
http://uk.farnell.com/productimages/...d/42349165.jpg
Nice one,
David.
Old 6th May 2006, 02:13 PM   #3
BWRX is offline BWRX  United States
diyAudio Moderator Emeritus
It looks nice and has a nice temperature range, but if it can only accept those special tips that he sells then I'd look for something else.
Believe it or not, it's actually easier to solder most surface mount parts (603 and up and fine lead pitch chips too) with a larger flat blade style tip. Be sure to get a flux pen or some liquid flux to make soldering easier too.
Brian
Old 7th May 2006, 02:09 AM   #4
You mean that the #3 tip in the 2nd link is no good?
I was thinking it was the right shape for 'do a row of pins at a time'.
Also, lots of flux dispensing bottles on ebay, even empty flux pens but where do you get a bottle of liquid flux in the UK?
Old 7th May 2006, 02:26 AM   #5
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
This is the soldering iron i have had for 5 years now never replaced a tip either.
http://www.ajdist.com/weller_ungar.htm
BUT i did just buy another weller because i don’t want to kill this one. The Weller 921 is really good with smd, but soldering thicker stuff wire, connectors it gets a little cold. Your best bet look for a weller soldering station on ebay and buy a base that will accept both small iron's and larger ones. You will thank your self for buying a weller when it works 100% every time and up to 10 years or more..
Here is one you could buy, both accept the soldering iron part to be removed replaced and interchanged with other types.
http://cgi.ebay.com/Weller-EC1002-So...QQcmdZViewItem
http://cgi.ebay.com/Weller-WESD51-So...QQcmdZViewItem
Old 7th May 2006, 08:49 PM   #6
The best way to solder a row of pins is with a screwdriver blade type tip. You wet the row of pins with flux, clean the tip, put enough solder on the tip, and gently slide the tip down the row and all of the pins will have a nice solder joints and you shouldn't have any bridged. It takes a bit of practice to get the technique down.
You can get flux pens (filled) from places like digi-key and probably farnell over in europe. I like the Kester 186 RMA flux pens.
Brian
Old 7th May 2006, 09:01 PM   #7
Those soldering stations are junk. They are sold by a car accessories place in sweden called biltema www.biltema.se
They are just a regular 230v iron with a oversized "dimmer" on it.
Old 8th May 2006, 12:07 PM   #8
Thanks for the warning. I'm watching a Weller iron and Decibel Dungeon has an article about building the 24v supply.
Also, I have a voltage controller (2.4Kw) and the dmm I'll be buying has a temp probe. If I got a 50/60w 230v cheapo iron with the right bits could I use it after some diy calibration? Not an ideal soultion I know but my immediate plans are for building a max of 3 x Amp3, that plus a good smd capable soldering station comes to more than 3 x Charlize.
Old 8th May 2006, 05:10 PM   #9
Don't worry about the iron's temp too much, just don't heat the parts for too long and you shouldn't have any problems. That's where flux helps, the solder gets wicked to the pad and the part almost instantly, minimizing the amount of time you need to keep heat on the parts.
If you plan on doing any other bench type of soldering work (like diy audio projects ) in the future it would be wise to get a decent soldering station now instead of a standalone iron.
Brian
Old 8th May 2006, 06:12 PM   #10
Banned
Don't buy a soldering iron and build your own psu. Just splurge and buy a station there less than a 1000$ now. It's well worth it.
Recommend a Soldering Station kvk Equipment & Tools 44 6th May 2010 09:04 PM
Soldering Station I'd like to built Renatomcl Equipment & Tools 1 15th April 2009 01:15 AM
WTB soldering station prezden Swap Meet 6 28th November 2008 08:45 PM
SMD soldering station hbarki Parts 10 27th October 2008 07:17 PM
which soldering station? David B Parts 11 15th May 2005 03:59 AM
Page generated in 0.11780 seconds (77.55% PHP - 22.45% MySQL) with 10 queries
