Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th May 2006, 08:27 PM   #1
Send a message via AIM to IMPALAMAN1
Default LOOKING FOR Pot!
no not that kind......
im looking for a particular pot. it is an alps a10k. it is a lime green color with a splined shaft, horizontal panel mount.
the piece is labeled alps taiwan on the back.
either that or some thing that would be a direct replacement upgrade.
possibly a blue velvet?
thanks,
D
linear power/ oz audio/ clarion
Old 5th May 2006, 09:53 AM   #2
IndyAudi's Avatar
Default Re: LOOKING FOR Pot!
Originally posted by IMPALAMAN1
It is an alps a10k. it is a lime green color with a splined shaft, horizontal panel mount.The piece is labeled alps taiwan on the back.
Sorry,I don't have one but is this the 'Alpha' pot that you meant ?
Old 5th May 2006, 02:45 PM   #3
SURE LOOKS LIKE IT. THANKS. ILL LOOK INTO ALPHA.
Old 5th May 2006, 03:34 PM   #4
looks like ALPHA wants a 1000 min order. know of any where i can get these?
Old 7th May 2006, 06:48 PM   #5
MOER is offline MOER  United States
Default pots
Must it be an "A" taper? We have thousands of new pots of this 9mm style in stock
Zed Audio Corp.,
www.zedaudio.com
805 526-5315 PST voice
Old 8th May 2006, 03:19 PM   #6
Default i believe so
there is an a taper in there now. i didnt think the 2 were interchangeable.... looks like im going to have to do a search.
Old 10th May 2006, 12:23 AM   #7
Default WHAT IS THE DIFFERENCE
BETWEEN THE A AND B POTS. will one work in the place of the other? what are the concequences if you mix them up
Old 10th May 2006, 08:27 AM   #8
mobyd is offline mobyd  New Zealand
mobyd's Avatar
A= log (use these for volume controls)
B= linear - DON'T ^^^^^^^^^^^^^^
Mouser have a great range of splined 9mm Taiwan Alpha pots
M
Old 10th May 2006, 02:40 PM   #9
Default INTERESTING
hey fellas, i noticed that my other piece has all 3 pots as the B taper. so now im curious as to why this is. i called a buddy that has 3 of the same pieces of equipment. same thing. some had the 1 had all A pots, 1 had all B pots and 1 had a combination of the 2 A pots and 1 B pot. the B pot being on the highpass.
i did notice that the volume was significantly louder on the pieces with the B taper.
any thoughts?
the processors with the B pots have all been modified with burr brown chips might that have anything to do with it?
Page generated in 0.08275 seconds (79.31% PHP - 20.69% MySQL) with 9 queries
