Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 4th May 2006, 02:46 AM   #1
Default Please!!
Can anyone tell me where I can get insulated thermal pads for the LM3886 and LM4780? And the insulating washers?
And yes I have searched but all I can find is mica pads for transistors.
Poor stereo mix? Switch to mono! Perfect.
Old 5th May 2006, 02:14 AM   #2
Nobody????
Maybe wrong thread?
Old 5th May 2006, 11:27 AM   #3
rabbitz is offline rabbitz  Australia
rabbitz's Avatar
Just have a look at some of the larger transistor ones that are about 25mm x 38mm and add the extra hole. I ended up getting some for the MT200 package which only needed a slight change to the hole centres.
You should be able to pick up the insulating washers anywhere.
The LM4780 is an awkward chip to mount and is possible for the holding screws to short on the body of the chip (so I found out). Ended up making a plate to sit over the front to keep the screws apart and insulated the screws between that and the heatsink.
No longer DIY active
Old 5th May 2006, 11:39 AM   #4
testlab is offline testlab  United States
testlab's Avatar
Mouser has the insulators you are looking for.
It's not whether you win or lose, it's how you lay the blame.
Old 5th May 2006, 12:41 PM   #5
Thanks guys. If Mouser has them, what do I search for? Seems like everywhere you go, they are called something different. I searched "Thermal Pads" and "Insulating Pads" no luck.
Old 5th May 2006, 12:46 PM   #6
Silpads. Silicon rubber.
Page generated in 0.07490 seconds (72.86% PHP - 27.14% MySQL) with 10 queries
