| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I've done some poking about but so far I'm unabvle to find the answers I need...
Here's the problem. I have a 101 Disc CD Changer with no volume control running directly into a PA system at work. The PA's volume control is extremely touchy and is either off or blaring. I'd like to build a small box to insert between them - two rca inputs, two rca outputs and a volume knob. It doesn't need to be fancy I just don't have the technical knowledge to create it. I'm sure I can build it, I just don't know where to start. Any help would be greatly appreciated. Thanks! |
#2 |
diyAudio Moderator Emeritus
http://sound.westhost.com/pots.htm
That's a great page to get you up to speed on all you need to know about making a very simple volume control.
Brian |
#3 | |
Nigel Goodwin |
#4 |
your CD player probably has ~ 2V output whilst the PA input could easily be ~ 100mV input, i.e. far too sensitive. All you need to do is make up a dual phono to phono cable, and use good sized plugs at the far end with enough room. At the far (PA) end solder in a 10K series resistor and 1K parallel (i.e. 1K resistor pin to case, 10K pin to signal). job done. |
#5 |
Thanks very much! I think that's just what I needed!
#6 |
One more question!
The wiring diagrams I'm looking at show two pots - one for the left channel and one for the right channel. How would I make one volume control to regulate both at the same time? Forgive me if I'm asking silly questions - I'm a total noob. Thanks again. |
#7 | |
you use a stereo pot (that's two in one) |
#8 |
if you make up the two resistor attenuator as in post4 you do not need another pot. The attenuator alone will give about 20db of cut and should bring the existing volume control back to a sensible control rotation. Provided the volume control on the PA is working properly. Could it have a broken track?
regards Andrew T. |
#9 |
I built the stereo pot and four rca jacks into a small radioshack project box - I haven't used it on the PA yet, but it seems to function properly in my home tests...
Thanks everyone! |
| Volume control on DVD player remote. Lose resolution at low volume? | Circlotron | Digital Source | 2 | 10th June 2011 07:20 PM |
| basic question on volume control | wkang598 | Parts | 4 | 15th June 2008 04:49 AM |
| Volume control for 41hz Amp6 Basic | rca9449 | Class D | 10 | 14th June 2007 03:20 PM |
| A basic chipamp in a not so basic case. | waltson | Chip Amps | 19 | 24th August 2005 07:40 AM |
| Basic circuit drawing software | JDeV | Everything Else | 7 | 2nd February 2003 02:13 PM |
| Page generated in 0.11157 seconds (78.37% PHP - 21.63% MySQL) with 10 queries |
