| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
I'm looking for an OP-amp IC that can work at +/-30V or more, performance about LM301 would do. Thanks for any suggestion. |
#2 |
you might be lucky, but be prepared to build yourself a discrete opamp.
regards Andrew T. |
#3 |
Electrons are yellow and more is better!
Depending of what you are going to do you will have various options.
First, what is your application? Bandwidth, output current, gain?
/Per-Anders (my first name) or P-A as my friends call me |
#4 |
You could try OPA551 (15V/usec +/-30V supplies)
or OPA445 (15V/usec +/- 45V supplies). Both are still available from TI. |
#5 |
From quick look to National's opamp selection quide:
LH0004 +/- 45V LM143,144 +/- 40V |
#7 |
Thanks for your suggestions, I think LM143 would be the right candidate. In the schematic I want to change the 7815/7915 to 7824/7924, that's higher than the supply V of LM301.
| Page generated in 0.09113 seconds (76.56% PHP - 23.44% MySQL) with 10 queries |
