| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Anyone know a site that show you how to build a similar device to the LT Phase Check : http://www.lt-audio.se/produkter.htm
Thanks in advance, Francois Gregoire aka Dark Shadow |
#2 |
Elektor had a projekt that did just that. Check with them for a reprint maybe or if somebody here has it? It had a sender and a receiver.
http://www.elektor.co.uk/ /UrSv |
#3 |
Thanks for the info but.... The link that you gave me don't seem to work =( will try later...
#4 |
Warp Engineer
On Holiday
The link given above is incorrect, try http://www.elektor-electronics.co.uk/
#5 |
Sorry for the link...to quick...
/UrSv |
#6 |
I check the WBE site but... I can't find the project...=(
Do you remember the year and even better the issue that this project was featured? Thanks in advance. |
#7 |
#8 |
After looking on the elektor WEB site I still not find the project. I emailed the magazin and here the respond I get:
We refer to your email regarding the above. No such project from Elektor, or it must be very old, try eit "phase". Kind Regards Lesley Kelly Even the magazine don't know where is it....=( Ahyhow....One day I will find it... |
#9 |
On Hiatus
Remember that these numbers of edition can differ
because swedish edition of Elektor comes 1 or 2 months later than the original. Phase indicator: Generator have line out or a little speaker. Receiver have line in or an electret microphone. In or out of phase is indicated by 2 different LEDs. This was in Elektor 11/90 (#11 1990, Sweden) Phase Meter, a pecision instrument. Digital display. 10 Hz - 20 000 Hz, 0-360 degrees, fault 1,2 or 5, depending on timeperiod, max 10 seconds. Input 0.006 mV - 100 Volt, 1 Mohm Elektor 6/91 Phase Meter, low price. Digital display 0-360 degrees. Impedance 1 Mohm. Elektor 6/93 Simple Phase Meter. Impedance 1 Mohm. DC-voltage output for Digital Voltmeter showing the phase difference. Does not show which channel is before or after. Elektor 1/97. All 4 projects have PCB-layout. I wish I had a scanner. But someone else might have. When I get enough money over, I will buy me one. A good one! |
#10 |
That's a disgrace that they didn't remember and they are the ones that publsihed it...
The one in #11 Swedish is the one and that project was in the English one as well as I bough only English editions at that time and I remember it clearly and I think they even had the front panels for the project. See if you can get somebody to scan it as I think it is exaclty what you want. Even I would like a copy since I threw out all my complete years of Elektor since 1983... /UrSv |
| speaker phase check | sma | Swap Meet | 0 | 12th February 2005 07:45 AM |
| Great project interest check | amisdad | Multi-Way | 4 | 6th October 2004 04:46 PM |
| P105, ESP's New ESL Project! Check It Out! | jamesjung21 | Planars & Exotics | 9 | 15th June 2004 06:22 AM |
| Page generated in 0.09969 seconds (78.96% PHP - 21.04% MySQL) with 10 queries |
