| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hello.
I've received an Guitar-pedal from a friend an found out that the Opamp was defect. So I changed a TL064-type with a TL084-type. The pedal now works fine, so my question is: Is the 084 a suitable replacement for a 064? Keep in mind that this things are powered by a 9V-Battery, so power consumption matters. Thanks in advance for your help. |
#2 |
TL084 has higher power consumption, but less distortion. If that's the only active part in the unit, the battery will last maybe 6 to 8 times longer with the TL064. Other than that it should work fine.
#3 |
Hi.
After telling him that he told me that he also could power it by 48V phantom power or wall wart, so it shouldn't be a problem. Thanks for your info, paulb, helped me a lot. edit: Now I know, the number i have/had to look at is Iq. TL064 Iq per channel(Max)(mA): 0.25 TL084 Iq per channel(Max)(mA): 2.8 Just for your/my information |
#4 |
what does the pedal do? if it is distortion or overdrive it will sound different than originally intended.
#5 |
Hi.
It's an active DI-Box with Speakersimulation (RED BOX MK III, Hughes&Kettner), so the quad opamps are used as active filters. If you are interested in such a schematic have a look here: GeneralGuitarGadgets |
| 12AU7 substituted for a 6922 | john65b | Tubes / Valves | 7 | 19th August 2007 08:32 AM |
| TL084/TLO74 replacements | afxdave | Chip Amps | 4 | 18th March 2004 06:43 PM |
| TL074 vers. TL084 ? | lohk | Solid State | 17 | 20th January 2003 12:37 PM |
| Page generated in 0.07903 seconds (73.25% PHP - 26.75% MySQL) with 10 queries |
