Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 22nd April 2006, 07:58 AM   #1
Bobhof is offline Bobhof  South Africa
Default Basic wiring problem
Hi All. I'm new here so please be patient with me. I am busy building a set of speakers with a built-in amp (you can see my system design in this thread: Help with ar.com kit from madisound). The amp only has one input but I need to play audio from a DVD player, computer and auxiliary source as well as output to either the amp or to my headphones. I would rather not use any switches. I came across some wiring diagrams on Shavano Music Online (http://colomar.com/Shavano/patchbox.html) and modified it to take 3 inputs and added a switched jack to the output. My design is as follows:
Is this okay? Will there be any sound degradation as a result of the resistors?
Must all the grounds in the image be linked to each other?
Thanks,
Rob
Old 22nd April 2006, 12:06 PM   #2
Limhes is offline Limhes  Orkney Islands
You might want to use some DC blocking caps just before the three inputs, to make sure there is no DC current between any of the devices attached. The rest will work, as far as I can see.
Old 22nd April 2006, 02:51 PM   #3
Default Will do
Thanks. I will see if my electronics shop has any of those. Does one join them to the wiring and, if so, do I need to put one on each of the incoming wires?
Bridge & Parallel 4 x LM4780 - Basic wiring diagram needed GAH Chip Amps 13 12th August 2009 01:37 PM
Basic Transformer hookup wiring wicked1 Tubes / Valves 3 24th January 2009 12:21 AM
tranformer wiring problem ebenai Power Supplies 2 7th May 2007 08:35 AM
basic wiring for t-amps HELP! miles488 Chip Amps 3 6th February 2006 08:41 PM
Help with basic Thorens TD-160 problem Chris Balton Analogue Source 5 5th January 2006 08:08 PM
Page generated in 0.09450 seconds (68.43% PHP - 31.57% MySQL) with 10 queries
