Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 21st April 2006, 03:38 AM   #1
Default Help locating some parts.
They are little silver cans labeled
34254
100
25v
Old 21st April 2006, 06:35 AM   #2
ifrythings's Avatar
They almost sound like caps, but I've never seen a cap with 34254 on it. The other numbers (if it was a cap) would probly be 100uF@25V
P.S it's not the little guy on the top of the picture is it?
Old 21st April 2006, 04:02 PM   #3
Yeah it looks similiar to the one on the top of the picture, very similiar.
They are from a Samsung monitor, they are allow bown up so I only know what they mostly look like, but that looks like it.
Old 21st April 2006, 05:52 PM   #4
paulb is offline paulb  Canada
That is a surface mount aluminum electrolytic capacitor.
Old 21st April 2006, 06:05 PM   #5
Any idea who sells those specific ones? I suppose it is not imporant to be surface mount as I can not physically do that.... I am going to be attaching leads to leads...
Old 22nd April 2006, 06:43 AM   #6
ifrythings's Avatar
Digikey has those caps but not sure if there is a place closser to you.
Those caps are very easy to solder on and off of board, the leds bend out then around the cap so you can heat the pins from the sides to get them off.
P.S check Digikey's web site, they may have a location close to you.
Old 22nd April 2006, 09:42 PM   #7
There are no solder connections on the bottom of the PCB... I am going to have to do this top side.
Old 5th May 2006, 02:42 AM   #8
Do you think they are non-polar or ?
Old 6th May 2006, 05:18 AM   #9
ifrythings's Avatar
They usualy have a black painted spot on the top of the cap which means that the pin below it is negative(-).
Old 6th May 2006, 06:06 AM   #10
It is literally impossible for me to know which pin... These capacitators blew up so the caps where rattaling around.
locating parts in eagle branm Parts 2 23rd December 2008 08:00 PM
Need help locating a jog switch jc2 Parts 0 29th December 2006 08:15 PM
Locating transistors Canefire Solid State 10 29th December 2006 02:30 PM
Locating fairchild parts Safe_Cracker Parts 4 19th January 2006 03:15 PM
Locating Speaker Parts? FrankRoss Parts 0 26th February 2004 01:23 AM
Page generated in 0.09284 seconds (72.31% PHP - 27.69% MySQL) with 11 queries
