Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 20th April 2006, 10:49 PM   #1
Default Vampire BFBP
I wanted to have a nice thumb screw style binding post on my upcoming DIY amps similar to the fantastic posts found on Mark Levinson gear. The closest thing I could find to ML's post is the Vampire BFBP. There seems to be little or no online data for the BFBP, so on whim, I bought a pair to check them out. Here's how the Vampire BFBP shapes up:
Cost around $30 per pair. Overall dimensions 65 mm long closed and 68 mm long opened. 4.5 turns closed to open. Thumb portion 40 mm wide. Not a true 5 way binding post. Only accepts spades. Appears to require a 14 mm square hole in the chassis with maximum chassis thickness of 10 mm.
Subjective parts quality is good--probably not on par with WBT posts, but these are significantly cheaper.
Likes: Thumb wheel operation for binding post
Dislikes: Isolation bushing is a little shy on beefiness where it counts. Only one millimeter distance separates conductive binding post from chassis. Will need to buy a punch to install them reliable.
Old 15th August 2007, 10:05 PM   #2
Default Vampire BFPB Binding Posts
Hi Orthoefer,
Have a Levinson ML-3 and are considering the Bindingposts you describe in this posting. Any more thoughstDo you know who makes the Levinson wingnut style Posts now?
Behringer Vampire lx-210 parts/Manual ShorBird Solid State 0 10th August 2008 01:35 AM
Vampire 26ga CCC magnet wire rabbitz Parts 0 15th April 2008 08:15 AM
Vampire XLR hum4god Swap Meet 1 25th April 2007 08:01 PM
vampire bindings posts f.bcn Chip Amps 2 2nd February 2006 08:10 AM
WTB: WBT/Cardas/Vampire Connectors bacworth Swap Meet 0 28th June 2003 09:22 AM
Page generated in 0.06399 seconds (70.28% PHP - 29.72% MySQL) with 11 queries
