Go Back   Home > Forums > Design & Build > Parts
Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc.
Old 12th April 2006, 04:25 PM   #1
MGH is offline MGH  United States
Unhappy Any good source selector?
I'm looking for a high quality (not high price) source selector to go along with my DACT CT2 attenuator. The DACT selector is too expensive ($80). Anything around $20-40 range that is just as good? Thanks.
Old 12th April 2006, 05:05 PM   #2
Rodeodave's Avatar
Maybe Elma?
http://www.elma.com/us/products/rota...y%20Switches/5
Gravity - Making the G since 13.7 billion B.C.
Old 12th April 2006, 05:09 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Grayhill from Digi Key is good and still reasonably priced.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 12th April 2006, 05:27 PM   #4
protos is offline protos  Greece
protos's Avatar
look at these
http://dkc3.digikey.com/PDF/T061/1431.pdf
I think you don´t need very expensive switches in our hobby.
Old 12th April 2006, 08:21 PM   #5
Thanks! Where can I order the Elma in the US? There are so many grayhills - I only need 3 or 4 selector switch. Which do you recommend?
Old 12th April 2006, 08:38 PM   #6
Here's the link to Grayhill info: http://www.diyaudio.com/forums/showt...804#post408804
www.audiosector.com
Old 12th April 2006, 08:40 PM   #7
Default Try Centralab
Cnetralab is an old company. They made rotary switches that put the current crop to shame. These are ceramic wafered, silver contacts, ball bearing types.
Ebay is a good source, a nice 4 - 6 position, 2 pole, non-shorting might run 3 - 4 dollars. I have used 4 pole for 2 pole and doubled up the contacts.
I bought a box full a while back, should never need a selector again. The 2000 series are steatite, ceramic. The 1000 series are phenolic wafer.
I have used the Elma in a cople preamps in the past, the Centralab are better in my opinion. Less noise, and smoother operation.
George
WTB source selector switch limono Swap Meet 1 23rd April 2009 07:47 PM
Stereo source selector IC speakerguy79 Parts 4 29th November 2008 01:16 AM
Relays for Source Selector SRMcGee Everything Else 1 9th November 2008 10:02 PM
source selector mnr102 Multi-Way 0 24th February 2008 11:11 PM
Here's a source selector DragonMaster Everything Else 0 7th August 2005 03:52 AM
Page generated in 0.08724 seconds (73.45% PHP - 26.55% MySQL) with 10 queries
