| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi.
I'm designing some electronics that needs to dissipate a lot of power. I'll be using a 19", 3 unit case and I'm thinking of using standard 100*160mm PCB's in a case like this: http://www.fischerelektronik.de/fisc....3.5.U.1.1.pdf I would like the heatsinks to be horizontal and not vertical. Any Ideas how/where to get a case like that? If a special case is not available, then maybe just a heatsink with the right dimensions? I'll be mounting a number of PCB's in the same 19" case, and I'm going for a solution that's as compact as possible (but not liquid-cooling though..) Regards TroelsM
Need more time... |
#2 |
How much is "a lot of power"? The Rth of your heat increases quite a bit if you mount it lying down instead of upright.
/U. |
#3 |
Hi.
It seems that I was in a bit of a hurry yesterday... I forgot some information: The case will be fan-cooled It might be ambitious, but I would like to dissipate something like 500-1000W in the 3U case... Yes it's a lot, and if it's impossible then I'll have to change my plans. There's going to be a number of these 3U-cases in the same rack If the air-flow is vertical then I'll either have to leave some space between each case or "re-cycle" the air and force it trough multiple cases. The latter approach will require some high-pressure fans and there is still the problem of trying to "cool" the top-case with the hot air from the bottom case... If the airflow on the other hand is horizontal then i could force the airflow from front to back in the rack. This would make each case more "independent" and I could stack them as high as I would like to. Hope this clarifies things. Regards TroelsM
Need more time... |
#4 |
http://www.behringer.com/EP2500/index.cfm?lang=ENG
is a 2 U rack mount "2500" W probably ~ 800 W being dumped at max [actually may be a little lower with "class H" ouput, little brother ep1500 has to be dumping 500 W with class AB ouput] should be able to find pics of insides I would consider buying a similar PA amp for such a project just for the hardware that already fits together - I can't buy the mechanical parts/hardware for the finished PA amp sale price |
#5 |
Hi jcx!
That actually not a bad idea! I don't know why I didn't look to the "PA-amp-scene" for inspiration... Although the idea about using a pro-amp-case i tempting, there are other restrictions to this project that might prevent from using this approach. Regards TroelsM
Need more time... |
#6 |
Please tell me if I'm wrong, but as to my knowledge, this behringer amplifier case are not suited to dissapate over 500W.
Those amp cases are entended for class T amps, where the heat is heat is less and where high peak outpout power doesn't create the same amount of heat as conventionel electronics and "older" amp types
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#7 |
the ep1500 is certainly plain jane class ab so it has to be over 500 W pdiss when you throw in some ps inefficency - if the ratings were honest
| FS: Metal Case Enclosure, Inductors, heatsinks | durwood | Swap Meet | 1 | 19th May 2009 01:28 PM |
| Court case, AER Vs "AER" | OzMikeH | Full Range | 6 | 9th January 2008 10:12 AM |
| Krell KSA-50 kit for sale with case/heatsinks/everything | Jed | Swap Meet | 11 | 29th April 2007 05:46 PM |
| suggestions for where to get some heatsinks\case | roofingboom | Parts | 3 | 1st June 2004 01:31 AM |
| Pass A-40 Amp Parts, All minus PS, Heatsinks, and Case | roddyama | Swap Meet | 5 | 20th April 2002 05:42 PM |
| Page generated in 0.10294 seconds (77.30% PHP - 22.70% MySQL) with 10 queries |
