| Parts Where to get, and how to make the best bits. PCB's, caps, transformers, etc. |
Hi all,
what is the difference between NPO and COG ceramic capacitors? How might it affect their intended end use?
regards Andrew T. |
#2 | |
"Negative-Positive-Zero" as tempco is +-30ppm |
#3 |
Thanks Mzzj,
What is C0G?
regards Andrew T. |
#4 |
COG is the name of the dielectric type.
Looks like Sponge Bob has killed another thread. |
#5 |
C0G capacitors have excellent dielectric characteristics which compete with better film varieties: low distortion, low DA, low DF. X5R capacitors, and its siblings, are another matter entirely having dielectric characteristics that compete with the worst of electrolytics for Worst Capacitor Ever.
Tom |
#6 |
Seeing as I mentioned the dreaded X5R, here's a distortion plot of an X7R. Says Cyril Bateman who performed the test generating the plot:
"This 10nF X7R ceramic was made by a CECC approved, European manufacturer. It was tested at 1kHz and 3 volts, in series with a 10k ohm current limiting resistor. Measurable distortion exists at all voltages down to 0.5 volts – my lowest test voltage."
Tom |
#7 |
Here's the same test on a C0G.
Tom |
#8 |
I've been using NPO/COG caps in a variety of places with extremely good results,..at least to the ear.
#9 |
Hi Serenq,
that's some difference -63db (x7r) reduced to -127db for the C0G. Thanks to all. Is the low distortion an indication that ppm/V is not an issue for C0G and NP0 when used in Audio locations. We all use ceramic in bypass duty.
regards Andrew T. |
#10 |
Hi Tom,
Thanks for the plots. Do you have the test configuration diagram? Too bad ceramics a got a bad rap in the audio world. They are really good performers if used properly. But can a nightmare if misused. (piezo microphonics). I still use em X7R included and could not be without. Generally use for low imp/supply bypass. Never in high imp/ high gain circuits like feedback networks. NP0's abound in RF world up to several GHz.
like four million tons of hydrogen exploding on the sun like the whisper of the termites building castles in the dust |
| ceramic capacitors .... | sakis | Solid State | 189 | 16th April 2009 07:26 PM |
| Flat round and old ceramic disc capacitors | AndrewGM | Parts | 1 | 6th October 2008 10:19 PM |
| what is the difference between silver mica capacitors and ceramic capacitors ?? | prorms | Solid State | 1 | 6th May 2008 12:38 PM |
| life lesson on ceramic capacitors in signal path | mazurek | Parts | 11 | 23rd February 2006 04:00 AM |
| Page generated in 0.09652 seconds (80.58% PHP - 19.42% MySQL) with 11 queries |
